SolaraGuy.com • View topic - Can anyone school me on how to put on my apexi meter
Postby anwagbo3000 » Tue Nov 20, 2007 6:37 pm
I got a Apexi Speed/rev Meter and i want to put t on, i tried to sell it on ebay but had no buyers.
So i would like to put it in my car, can anyone help
i have searched and found nothing
Help is needed and appreciated
anwagbo3000
Postby dvdchris45 » Tue Nov 20, 2007 8:01 pm
and what benefit do you see getting out of this meter?
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby iinokturnolii » Tue Nov 20, 2007 9:38 pm
you got no replies here....
http://www.solaraguy.org/viewtopic.php? ... ht=#387074
not much help here also...
http://www.solaraguy.org/viewtopic.php? ... ht=#393722
and you probably wont get one here... :roll:
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
Re: Can anyone school me on how to put on my apexi meter
Postby Gadgetjq » Wed Nov 21, 2007 8:30 am
anwagbo3000 wrote:I got a Apexi Speed/rev Meter and i want to put t on. i have searched and found nothing
I see you've been trying to do this since July.
Suggestion:
1. Download the wiring diagram for your '04 from the Toyota Technical Information System ( https://techinfo.toyota.com)
2. Invite a buddy to your place or take your car to someone elses garage so you have an extra set of eyes/hands to help out.
3. Provide appropriate snacks and libation.
The install can't be all that difficult. Instructions posted online show only four wires
1. Red = Ignition On Find that using a test light or voltmeter
2. Black = Ground That can be any bolt behind the dash you can confirm as ground using a continuity tester
3. Yellow = RPM signal You'll need the wiring diagram
4. Purple = Speed signal Wiring diagram again
Where you mount the meter is entirely up to your sense of style/taste but should be easy to get an eyeball on. I see you can buy a mounting bracket for the unit but you might want to try Velcro first.
Cheers :cheers:
Gadgetjq
Postby Astro » Wed Nov 21, 2007 12:06 pm
DO NOT USE A TEST LIGHT! Test lights are very dangerous for our vehicles and may damage circuits, relays, etc. USE A DMM (Digital Multimeter), you'll be able to test for everything safely.
1. Ignition= You can find the ignition wire under your steering column. Just take off the cover and find the wire. I don't know the color since I've got a '00.
2. Ground= Like mentioned, find a bolt behind the dash.
3. RPM= You can find it behind the speedometer, check the wires in the connector(s).
4. VSS (vehicle speed sensor)= Also found behind the speedmeter.
Postby onefiend » Wed Nov 21, 2007 2:16 pm
dvdchris45 wrote:and what benefit do you see getting out of this meter?
it makes the interior of the car seem faster?
2007 Camry SE V6
onefiend
Postby anwagbo3000 » Fri Nov 23, 2007 8:16 am
Thanks guys, I am going to print out this page a view all the links and hopefully I can get this project underway
anwagbo3000
