SolaraGuy.com • View topic - What does tsb mean? and how to get the dealer to fix problem
Postby bub » Sun Nov 25, 2007 11:04 am
what exactly does tsb mean? im in car biz i have been a salesman for about 3 1/2 years and i dont know what it means? lol but then again i work small indepent lots..anyways im taking my 04 sle in to toyota tues. for the hesitation problem that theyt all seem to have..i have read alot about this and it seems theres a computer flash tc00-05 for this? but when i called my local dealer about it he acted like hes never heard of it and there no recalls or info about this problem,also i have the loud sunroof problem as well which i read in here there is a tsb for that as well,but what is tsb and how do i point this out to my dealer and is it going to cost me or no? i believe my car is out of warrenty.. thx
bub
Postby Sebas007 » Sun Nov 25, 2007 11:17 am
TSB stands for Technical Service Bulletin (some think it is Toyota Service Bulletin)
Those 2 problems had been disucted and you can find the TSB number in the Sticky http://www.solaraguy.org/viewtopic.php?t=18334
Those problem should be fixed without any fees even if you're out of your warranty. Just tell a diagnotic reflexting the points on the TSB and if they hesitate just tell them you make your own search and that you heard about the specific TSB...they will have no choice to fix it.
TC006-05 ECM CALIBRATION: SHIFT FEELING ENHANCEMENT 2005-06-03
NV004-05 Moonroof Grinding Groaning noise
Postby bub » Sun Nov 25, 2007 11:48 am
so they cant charge me labor,or parts or for the computer update? and the y have to fix my sunroof?? not one cent?
bub
Postby Sebas007 » Sun Nov 25, 2007 11:59 am
bub wrote:so they cant charge me labor,or parts or for the computer update? and the y have to fix my sunroof?? not one cent?
Correct...your VIN will have to be identified and from there they will check if your car is covered....but if you have an '04 those 2 problems enumerate above are covered. Now do your part !!
Postby [SMAN] » Sun Nov 25, 2007 12:17 pm
if you have an 04, you better do it quick. The sunroof only had a 3 year warentee, and unfortunatly mine ran out about 3 months before i bought the used car. The shifting thing is still doable cause it ocmes under the 8 year warentee.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby Sebas007 » Sun Nov 25, 2007 12:22 pm
[SMAN] wrote:if you have an 04, you better do it quick. The sunroof only had a 3 year warentee, and unfortunatly mine ran out about 3 months before i bought the used car. The shifting thing is still doable cause it ocmes under the 8 year warentee.
I don't think you need to be under warranty...it is a recall like thing. Surely it is a no brainer when you're under warranty
Postby [SMAN] » Sun Nov 25, 2007 12:26 pm
really? cause they told me that cause i was out of warentee that was listed on the TSB that it was no good.
2004 Solara V6 SE
1996 Camry I4
[SMAN]
Postby Sebas007 » Sun Nov 25, 2007 1:11 pm
TSB listening
http://www-odi.nhtsa.dot.gov/tsbs/
I took it from a Dodge Ram forum...it backup my thoughts
What if my dealer can't or won't fix a problem? Can I get a dealer to cover a known problem after the warranty expires?
If the problem was documented before the warranty expired, the dealer will perform the repair under warranty but, you may have to produce the documentation and fight for warranty coverage. For example, if I brought my truck into the service department complaining about transmission noise and the service department said it sounded normal to them. Then 2800 miles out of warranty, the transmission looses a synchronizer and bearing. I would take the service ticket where they said "no problem found" and insist that this repair be covered under warranty. The dealership will attempt to say the problem was unrelated, but usually they will capitulate and cover the repair.
An other source who tells the opposite.
http://www.canadiandriver.com/articles/jm/warranty.htm
Technical service bulletins (TSBs) are diagnostic tools, not warranties. Automakers determine if a symptom might indicate a specific repair, and issues the TSB for the technician's use. For example, a failed sensor may cause a vehicle to run rough. By checking your vehicle's symptoms against the TSB database, the technician will hone in on the sensor first, instead of wasting time checking the vehicle's entire system.
Postby [SMAN] » Sun Nov 25, 2007 1:26 pm
Yeah but see i purchased my car after the 3 years was up, cause i had one of those rare 2003 04s, so it was up before 2007.
2004 Solara V6 SE
1996 Camry I4
[SMAN]
TSB
Postby JMSinMaryland » Sun Nov 25, 2007 3:01 pm
TSB are addressed if someone comes in with the issue vs. a recall where everyone is notified. TSB's have expiration dates, some are 3/36, some 8/80, etc depending. On the TSB at the bottom it lists how long of a period is covered. Jon.
JMSinMaryland
Postby bub » Thu Nov 29, 2007 5:48 pm
so the out come was ..that my car still has powertrain warrenty left and they reprgramed the ecm,but they would not cover the sunroof..
bub
