SolaraGuy.com • View topic - Warranty Work - In the Nick of Time
Postby PXLpainter » Thu Nov 29, 2007 3:45 pm
With only 400 miles left on my ride before the 36k mi. cutoff, I was able to get some work done and covered under the warranty still.
On my way to Las Vegas on Monday, I checked my oil when I stopped for gas and noticed it was about a qt. low. I had it changed about 2500 mi ago but did notice a small leak of oil/grease on the passenger side in the driveway. So I happened to contact another member on the TS forums who is a service tech at the Toyota dealership in LV since I was going to be here for the week - he hooked me up and got me in the next morning. He took me back to show me that the leak was just the drain plug and it was loose (1/4 turn from finger tight) but the seal was leaking. He said that's common on the Camrys and Solaras and popped a new one in for me. Said to keep an eye on that when someone else does your oil changes.
Also - BOTH of the boots were leaking and spinning grease all over the place - inside my wheels, etc. I thought that was originally from the sh!t I sprayed on the Whiteline Sway Bar bushings, but it wasn't.
Found out that is another thing that is common on the Solara - lowered or not! They replaced those both for free - LUCKILY I had the TRD springs and not COs as they would have voiced the warranty on that! If I waited until I got back home, my warranty would have run out. :o
So make sure you check your CV Boots if you're still under warranty! :up:
...and keep an eye on those drain plug gaskets! ;)
Oh - BTW - the Solara made quite a hit here in LV - had everyone from teh sales manager and the techs all coming to look at the beautiful exhaust work JP has done! Wish I had brought my camera to take some shots from underneath too! Most had never seen the CP-e either - made a hit! :D
Postby NeFaRiOuS_SLE » Thu Nov 29, 2007 8:39 pm
You might want to edit the "BOTH of the were leaking" part.
Warranties are great, aren't they? My last run with an extended warranty covered about $1,200 worth of stuff (water pump, valve gasket, power steering line, a few other things)... Just wish my window regulator issue popped up then too.
Besides, the springs shouldn't be an issue, especially since there's the Magnuson-Moss Act.
Postby MCOjerry » Thu Nov 29, 2007 9:19 pm
I had the boot cover thing on one of my wheels replaced too, under warranty...but no more left :(
Postby woa_its_j3ff » Thu Nov 29, 2007 9:35 pm
damn you guys for having warranty.
i bought my car used without warranty. at 109k miles.
but bright side is I had a friend mechanic check out the car inside out and all parts that needed to be replaced or checked on have been. so my 'lara is still running strong!
