SolaraGuy.com • View topic - Auto A/C control problem
Postby HuggerCST » Mon Dec 03, 2007 8:23 am
I have a '05 Solara convertible with automatic A/C, and the digital A/C control panel is dead. I have back lights when the lights are on, but that's it. I have replaced the control panel with a used one, and got the same result. I have power at the fuses, and power at the control harness plug,(#s 19 and 20). I also have ground at #1. One thing that I thought was odd is that my manual shows a 10 amp A/C fuse in the underhood fuse box, but mine doesn't have it, and doesn't appear to be wired for it. Can anyone help me find the problem, or refer me to someone who can? The manuals here really helped, but I still havn't found the problem. Thanks
HuggerCST
Postby dvdchris45 » Mon Dec 03, 2007 2:51 pm
have you checked all the low profile mini fuses located underneath the steering wheel column, when i installed my system i blew 1 or 2 of those and had no heat a/c until i replaced them
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby HuggerCST » Mon Dec 03, 2007 7:16 pm
I've checked every fuse that I can find and they are all good. :(
HuggerCST
Postby Jai_Jai_Binks » Mon Dec 03, 2007 7:24 pm
you all are out of warranty?
Postby HuggerCST » Mon Dec 03, 2007 8:53 pm
Jai_Jai_Binks wrote:you all are out of warranty?
Yep!
HuggerCST
Postby HuggerCST » Thu Mar 20, 2008 9:07 pm
UPDATE: The problem was a shorted, or stuck actuator/motor that controls the fresh air/recirculate door.(Left of the engine computer, behind glove box) For some reason it was drawing the power from the control panel, but never blew a fuse. As soon as we unplugged the actuator motor, the control lit up and everything worked except the recirculate door. Replaced the actuator and now it's fixed. Just thought I'd post just in case anyone else had this problem.
HuggerCST
Postby Down2TheC » Fri Mar 21, 2008 4:45 am
Nice find. The recirc bugs me anyway.
Down2TheC
