SolaraGuy.com • View topic - New front brakes and TPMS
Postby dougd4885 » Mon Jan 07, 2008 3:04 pm
I have a 2006 Solara and I went to get an oil change, tire rotation, and brakes checked. I did need front brakes so they replaced the front discs and pads and did the tire rotation. On my way home the TPMS light came on. I am well aware of the fact that it uses the ABS system on my car. I stopped and did the initialization process thats in the book and it stayed off the rest of the way home.
Does anyone know if something special has to be done when changing the brakes so that the TPMS light does not come on???
When I got new tires the light came on but after I initialized the system it never came back on. It should be noted that this is the first time I am rotating the tires.
2006 Solara SE
4 cyl. - 5 spd. auto
Oceanus Pearl w/ Ivory Interior
-Escort 8500 x50 radar detector (blue)
-USA SPEC Dual Aux. Input
-Sirius Starmate Replay ST2
dougd4885
Postby Gadgetjq » Tue Jan 08, 2008 8:16 am
Doug,
Just rotating the tires will activate the low pressure warning system if pressures aren't very close to where they were at each corner 'before' the rotation. You'll want to check pressures and be sure they're where you normally keep them then reset the warning system again.
I recently had mine rotated. When they checked the balance the tire shop also added air to one tire for reasons unknown. The warning light came on a mile from the shop.
Cheers
Gadgetjq
Postby dougd4885 » Tue Jan 08, 2008 10:04 am
Thanks for your reply. I am guessing that is all it was. I will adjust the pressure today and do the initializing thing again.
I was just hoping that it was not because something special had to be done when replacing front discs and pads.
2006 Solara SE
dougd4885
Postby NightRider » Wed Jan 09, 2008 1:37 am
I had the same issue. I tried something different, As I was warming my car for the morning I held the TPMS button down for a few seconds then it blinked twice and now my light doesn't on anymore. I don't if I turned it off or what. Oh well I keep forgetting to read my book for this car.
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby Soarer24 » Fri Feb 22, 2008 4:03 pm
I recently replaced my tires and the TPMS light came on, its generally no big deal, just make sure all pressures are the same and once they are reset the system. The techs I know at a Toyota dealer said, to reset or initialize the system hold down the TPMS button until you see the light on the dash blink 3 times, then release the button. This will allow the system to be set at whatever your current tire pressures are. On the 2004 solara the system is rotational therefore its based on the rotation of the wheels, on newer model solara I believe the TPMS system is actually controlled by a bleeder valve located on the valve stem inside the wheel.
2004 Solara SE Sport (4cyl)
(Lunar mist metallic)
Alpine V-power AMP, 4-Alpine 6x9 type S,
Kumho ECSTA ASX tires, Rockford punch AMP
Rockford punch 12" sub
Soarer24
Postby PXLpainter » Fri Feb 22, 2008 7:10 pm
Soarer24 wrote:On the 2004 solara the system is rotational therefore its based on the rotation of the wheels, on newer model solara I believe the TPMS system is actually controlled by a bleeder valve located on the valve stem inside the wheel.
This system hasn't changed since day one of the Gen 2 Solaras.
Postby Down2TheC » Fri Feb 22, 2008 11:03 pm
Took me 5 resets within a week of putting new wheels on. Then it stopped. Give it a few more resets to get used to the new rig.
Down2TheC
Postby Soarer24 » Sat Feb 23, 2008 8:10 pm
Thanks PXLpainter, wasnt sure, thats why i said i "believe". A service advisor @ Toyota told me it might be a different system for the newer solaras cuz i wasnt really sure, so i guess he was wrong.
Soarer24
