SolaraGuy.com • View topic - srs light
srs light
srs light
Postby Aotoyota » Sat Jan 12, 2008 8:45 pm
So last week the SRS light comes on. and the airbag on/off light reads off when a passanger was in there.
I took it to the dealer. they said error code was B1650 which means that the SRS ecu isnt receiving information from the scale on the seat. dealer thinks that it is a short in the harness. $350 to diagnose/fix worse case. change the seat $4-5k! after that was said I picked up the car and tried to check the connectors and disconnect the battery thinking it would clear it all...
It didnt work~ so now Im wondering what you guys can come up with? before i go bend over for the dealer.
thank Again.
Aotoyota
Postby PhreakdOut » Sun Jan 13, 2008 9:15 am
Make: TOYOTA
Model: CAMRY SOLARA
Year: 2004 (example used)
Service Bulletin Number: 00905
NHTSA Item Number: 10019153
Summary Description:
OCCUPANT CLASSIFICATION SYSTEM: DTC B1785. THE SRS AND PASSENGER AIRBAG OFF INDICATOR LIGHTS REMAIN ON. *TT
Make: TOYOTA
Model: CAMRY SOLARA
Year: 2004
Service Bulletin Number: 00505
NHTSA Item Number: 10019154
PASSENGER AIRBAG INDICATOR LAMP MAY SWITCH FROM ON TO OFF FOR FRONT SEAT PASSENGERS WEIGHING APPROXIMATELY LESS THAN 100 POUNDS. TOYOTA. *TT
Make: TOYOTA
Model: CAMRY SOLARA
Year: 2004
Service Bulletin Number: 00204
NHTSA Item Number: 10009686
OCCUPANT CLASSIFICATION SYSTEM INITIALIZATION (DIAGNOSTIC TROUBLE CODE B1150 & B1650). *TT
Postby PhreakdOut » Sun Jan 13, 2008 9:16 am
Oh, and go to another dealer. Shame on them for not checking the TSBs first.
Postby Aotoyota » Sun Jan 13, 2008 3:41 pm
cool thanks! will it matter that I am out of warranty?
Aotoyota
Postby Biggi_e » Sun Jan 13, 2008 3:49 pm
Aotoyota wrote:cool thanks! will it matter that I am out of warranty?
it might but you can try and see what happens.
Postby Aotoyota » Sun Jan 13, 2008 7:49 pm
thanks for all the help, ill keep everyone updated
Aotoyota
Postby Aotoyota » Sat Feb 02, 2008 10:40 am
the problem ended up being a short in the harness which
ended up at $300.
and no it wasnt a factory oops, it was mine when i was taking my changer out from under there.so a $300 lesson..thanks for the help everyone again
Aotoyota
