SolaraGuy.com • View topic - Holy WOW it was like getting a chip installed
Postby Nebula6 » Tue Feb 05, 2008 2:44 pm
I did lots of geeksquad work for our local dealership and got to talking to the service manager and told him about some issues I was having and we looked them up and bam!!! there was a update for the computer and man it was fast before but wow all the lag is gone from the low end. Hell YA
Nebula6
Postby ClassySolaraGuy » Tue Feb 05, 2008 2:55 pm
This was on your 2005 Solara SLE V6? I'm looking to get my gurls 2005 Solara SE V6 done as well. What info did they give you?
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby PXLpainter » Tue Feb 05, 2008 5:08 pm
Yeah, well it had have been 2004/2005 and not later since there is no fix for our POS. :(
Postby dvdchris45 » Tue Feb 05, 2008 5:13 pm
f'sho getting that reflash made all the difference in the world
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Re: Holy WOW it was like getting a chip installed
Postby Gadgetjq » Tue Feb 05, 2008 7:04 pm
Nebula6 wrote: there was a update for the computer and man it was fast before but wow all the lag is gone from the low end. Hell YA
For others with '04-'05 Solara's with the 3MZ-FE 5 speed auto trans Nebula is probably referring to TSB C006-05. It's a reflash that (copying from the TSB)
These improvements include:
Reduced downshift lag when accelerating at speeds from 10 to 20 mph
Less gear hunting when driving on/off accelerator pedal at 20 to 30 mph
Improved response rate during heavy accelerating from a stop.
It does 'not' (unfortunately) improve shift response when in manual (sport) mode.
Cheers
Gadgetjq
Postby geminiz » Wed Feb 06, 2008 7:26 pm
Is this the same issue for the 06? I got this from alldata.com http://www.alldata.com/vehicle_owner/index.jsp
TSB Number & Issue Date TSB Title
SS002-07 APR 07 Engine Controls - ECU Flash Reprogramming Procedure
2006 Solara SE (2.4L w/5 speed automatic)
Lunar Mist
geminiz
Postby 04Frost » Sun Feb 10, 2008 8:19 pm
Was there a charge from the dealership to do this?
04Frost
Postby dvdchris45 » Sun Feb 10, 2008 8:19 pm
04Frost wrote:Was there a charge from the dealership to do this?
this is covered under warranty.
dvdchris45
Postby ClassySolaraGuy » Mon Feb 11, 2008 7:22 am
How about if your over 60,000 miles?
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby NightRider » Mon Feb 11, 2008 9:03 am
So what exactly would I go tell the dealer when I go take my car in for this? im 46K and have the platinum warranty for this car. Or would it be better to do this by TSB?
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby [SMAN] » Mon Feb 11, 2008 9:12 am
You know, i took my car in (04) to get this done last summer and i swear it didn't really feel like there was a change. While the reciept says they did it, i'm not sure they did (didn't cost me anything but my time). Is there a way to check if the update was applied without sending my car in for service?
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby Down2TheC » Mon Feb 11, 2008 10:20 am
The firmware verision is stored in the ECU. Unless you have the proper hookup, you'll need another Toyota to check.
Back when it came out, there were several that needed it done a couple times for it to take. Probably folks not following instructions. A few had to replace the ECU altogether.
Down2TheC
Postby PXLpainter » Mon Feb 11, 2008 12:55 pm
geminiz wrote:Is this the same issue for the 06? I got this from alldata.com http://www.alldata.com/vehicle_owner/index.jsp
If I remember right, this one only fixes the issue of people driving for extended periods in 3rd gear without upshifting to 4th. I don't want to do that as it will automatically upshift for me when I'm canyon carving! :x
Postby geminiz » Tue Feb 12, 2008 2:25 pm
Thanks for clarifying what that TSB is for, otherwise I would've felt like an idiot asking for my '06 be fixed. What is the actual TSB Title for this lag issue?
Lunar Mist
geminiz
