SolaraGuy.com • View topic - Rear brake strength
Rear brake strength
Rear brake strength
Postby anwagbo3000 » Sat Feb 23, 2008 9:05 pm
Whenever i use my rear brakes, they dont stop my back wheels the way i think they should, they sort of squeak to a stop, as i am expecting them to stop immediately, do you think i should get better brake pads or renew them, or would better rotors be the key, and if i change my back brakes then should i change my front ones as well.
so basically all around brakes or all around rotors or both and what could be my rear brake problem
anwagbo3000
Postby kingkakyle » Sat Feb 23, 2008 9:52 pm
how do u use ur rear brakes?
dont all 4 of them work when u hit ur brake pedal?
Postby DatSRBoi » Sat Feb 23, 2008 9:53 pm
Front breaks will always grab harder. There are ways to more balance them out but its not cheap.
Is your car a drum rear or rotor? If drum then thats the problem. If rotor then make sure the surface is good and get better pads but do not expect them to perform like the front.
Postby adam8080 » Sun Feb 24, 2008 1:17 am
Are you trying to "drift"??
adam8080
Postby ThatVietGuy » Sun Feb 24, 2008 2:37 am
By what you wrote, I'm assuming you're using your hand brake to stop.
I also assume you don't have an understanding about how a hand brake works: the hand brake IT DOES NOT OPERATE THE CALIPER.
It operates pads inside the hub that expand out to stop the hub from moving. Only useful when in neutral or stopping from 10mph or less :drinking:
ThatVietGuy
Postby Gadgetjq » Sun Feb 24, 2008 8:20 am
Like others responding to your post I'm a little confused but, also like the others, assume you're trying to e-brake.
The lever would be better called a 'parking' brake than an 'emergency' brake. The pads on the shoes aren't really designed to stop the car from speed and would wear out pretty quickly.
Pull a rear wheel, remove the brake caliper then pull the disk/drum assembly off. You'll see very quickly that you don't really have a problem, just a misunderstanding.
Cheers
Gadgetjq
Postby BadAngel » Mon Feb 25, 2008 6:01 am
DatSRBoi wrote:Front breaks will always grab harder. There are ways to more balance them out but its not cheap.
Your not supposed to balance them out, you do 70 percent of your stopping with the front brakes, thats how it is, and thats how its supposed to be. Changing this would mess up the breaking time. I think the engineers at Toyota know what they are doing, and you shouldn't be messing with something as dangerous as breaks. Remember, your life can depend on your breaks functioning correctly.
BadAngel
Postby anwagbo3000 » Mon Feb 25, 2008 11:02 am
Well, one, I'm not trying to drift.........lol........, two, I was just trying to figure out the difference between front braking power and rear braking power, and I also was wondering why my front brakes performed better than my rear brakes, and I was trying to figure out if I could get them to perform at the same level, meaning, getting my rear brake level to perform at the same strength as my front brake level, but I guess I need to do more research on something like this
anwagbo3000
Postby kingkakyle » Mon Feb 25, 2008 11:07 am
also just take a look at ur rear brakes
they are smaller than the fronts unless its some optical illusion
