SolaraGuy.com • View topic - Dangling sound from driver side door? any idea?
Postby koshoe » Thu Mar 06, 2008 8:08 am
I have problem with dangling sound while car driving..it didn't happen all the time. check with dealer body shop and they can't diagnose the noise. first they thought the left side mirror and they changed new but still. then they changed fabrics still having issue. it's been on going isse with dealer for 3-4 times visit and having the noise.they took off the door check inside the door reassembly the wire stil that noise didn't go away. such a annoying tone. Anyone have any idea and thanks for reply feedback..
koshoe
Postby kingkakyle » Thu Mar 06, 2008 10:51 am
does it sound like a tapping noise while u drive
like its almsot under you?
my mom has that on highlander and its probably the thermostat or something....the thing that measures the coolant temperature
Postby linmk2 » Fri Mar 07, 2008 10:30 pm
I'm not sure this will be of any help to you, but I had a noise, not loud, but bothersome. Like yours, it did not happen all the time and it sounded like it was coming from either the very front part of the driver door or the edge of the dash. One day I was drying the car off after washing it and I bumped the rear quarter panel with my hand. I heard the noise! This time it was much louder. I started bumping the rear panel to trace the noise. It was the rear license plate. I put some foam under it and noise was gone. While the noise sounded like it was coming from the door, if fact it was not. While you may not be a lucky as myself, you might try lightly bumping some of the outside panels and see if you can hear the noise. Just a thought.
Howard
linmk2
Postby Down2TheC » Sat Mar 08, 2008 12:03 pm
Did you pull a "Vacation" and leave your dog tied to the bumper?
lHoward's right, from the driver's seat sound direction can be very misleading. Helps to get another person in the car to try to locate it. (try backseat too.) I had one that I was sure was at the dash, but turned out to be the crossbar on the conv top right over my head.
If it only happens when you're fast, it's probably something loose in the wind on the outside. If it's anytime you're moving, then maybe it's a dragging thing from underneath. If you really think it's door, drive with the panel off.
If you post later and say that it was your seatbelt dragging, we'll all have to flame you. 8)
Down2TheC
Postby koshoe » Mon Mar 10, 2008 7:40 pm
kingkakyle -- Thanks for the reply. but sound doesn't come from under the body it was came out somewhere inside the driver side door..
Linmk2 -- I'll check my rear bumper again.. sometimes sound came from neither front or rear side of door so it's hard to say.. thanks for the tips.
Down2ThC -- the funny thing is if I drive fast it didn't hear anything. but when you turn or uneven road or some bumpy road in drive like 40mph and less then the dangling sound came out. .. I hold the seatbelt and check the seat belt cover and everything that I could as well but sound still somewhere inside the door :cry: ...thanks for the tips.
koshoe
