SolaraGuy.com • View topic - gen 2 ecu wiring diagram
Postby anwagbo3000 » Tue Apr 01, 2008 10:31 am
I'm installing my apexi rsm, and I need a ecu wiring diagram, I have searched the site and found wiring diagrams for the safc for the gen 1.5 or it might have been the gen1
Is the wiring diagram for the safc the same for the rsm, if not can someone point me in the right direction, thanks
I will keep searching the net to see what I can find, so far not so good
anwagbo3000
Postby anwagbo3000 » Tue Apr 01, 2008 3:59 pm
bump
anwagbo3000
Postby Gadgetjq » Wed Apr 02, 2008 8:19 am
There's a forum sticky labeled something like 'gen 2 repair manuals' (right above your post). The list includes an electrical pdf ( http://cns-design.ru/files/solara/pdf/EWD.pdf ) which should have the diagram(s) you need.
One tip. There's no need to 'bump' a thread (especially one that's only a few hours old). Your message will pop up as unread for everyone checking the forum who hasn't seen it yet even though it isn't highlighted as 'new' for you (since you've already read the post).
Cheers
Gadgetjq
