SolaraGuy.com • View topic - What gas should you put in a 2az-fe for max performance?
Postby lemmez » Wed Apr 30, 2008 7:30 pm
Does the octane of gas really matter?
The prices of gas don't bother me (i live in so cal too) *if you can't afford gas then don't drive*
which gas offers the best performance?
I will be going to split sec this Monday and i need to know if gas really makes a difference in performance.
lemmez
Postby onefiend » Wed Apr 30, 2008 7:43 pm
compression ratio on the 2AZ-FE is 9.6:1, so using 91 octane won't benefit you.
using anything higher than 87 octane won't make your 2AZ faster.
2007 Camry SE V6
onefiend
Postby Jon11582 » Wed Apr 30, 2008 7:45 pm
87 for max performance on 2AZ. Any higher is just burning more cash.
2000 Black Solara SE
Jon11582
Postby i20solara02i » Wed Apr 30, 2008 10:16 pm
not unless ur turbo =P
i20solara02i
Postby DatSRBoi » Wed Apr 30, 2008 10:45 pm
i20solara02i wrote:not unless ur turbo =P
Postby i20solara02i » Wed Apr 30, 2008 11:29 pm
rofl
i20solara02i
Postby Gadgetjq » Thu May 01, 2008 6:42 am
Run whatever your owners manual recommends. There's no performance increase to be had by burning higher octane fuel. Actually you can see a performance and fuel mileage 'decrease' burning higher octane fuel if the car doesn't need it.
Cheers
Gadgetjq
Postby gnegroni » Thu May 01, 2008 8:38 am
87 octane! Our cars, even with your level of modifications, do not extract any noticeable benefit out of higher octane gasoline. Turbo or high compression 2AZ-FE is another story.
gnegroni
Postby solara caper » Thu May 01, 2008 10:25 am
I run high compression on 87 theres no gain for me with higher octane and to tell you the truth iI dont find my 2az likes 91 octane and at $1.40 liter they can keep it
solara caper
Postby lemmez » Thu May 01, 2008 10:54 am
Thank you everyone for the reply
lemmez
