SolaraGuy.com • View topic - Center Console Door Problem
Postby Gunga » Thu May 01, 2008 1:32 pm
2006 Solara SLE.
The door on the center console, under the radio use to pop open with just the touch of a finger. Now I have to push in the top, and the grab the bottom of the lip and pull up.
Any ideas?
Gunga
Postby Aotoyota » Thu May 01, 2008 4:32 pm
maybe a spring popped out? take it out and check the sides..
Aotoyota
Postby rojamay » Thu May 01, 2008 4:48 pm
Mine is doing that. I took it out and the mechanism that makes the door raise has broken. I hope I can just get that one little pice. As you are looking at the door, it will be on the right side.
rojamay
Postby Gunga » Thu May 01, 2008 5:33 pm
How do you take the door out
Gunga
Postby kingkakyle » Thu May 01, 2008 7:10 pm
the pictures disappeared.....
but heres was a tutorial
http://www.solaraguy.com/viewtopic.php?t=15765
basicallt u removed the piece going from in front of the door to the glove box
and then the compartment with the door pulls right out
