SolaraGuy.com • View topic - tune up
tune up
tune up
Postby anwagbo3000 » Thu May 01, 2008 8:03 pm
so my car is approaching 60k and i wanna swap out spark plugs and spark plug wires, for my spark plugs i wanna go with some ngk iridiums, but i can not seem to find spark plug wires.
and i do not want to go with bosch products because i have heard bad reviews about them, i will continue my search tomorrow, but if anyone has any suggesstions or links, then jump on into the thread and help me out...thanks
anwagbo3000
Postby Jakecallun20 » Thu May 01, 2008 8:10 pm
Not sure what Gen2s use, but go with NGK wires from www.sparkplugs.com if you can, there is a 1MZ set for like 37 dollars.
Postby anwagbo3000 » Sat May 03, 2008 12:40 pm
so im going with some NGK Laser Iridium long life spark plugs, i will order them later today unless some people disagree with their performance
anwagbo3000
Postby Gadgetjq » Sun May 04, 2008 7:55 am
Anwagbo,
The GenII's come from the factory with Iridium plugs which are scheduled to be changed at 100,000 miles. Just install what your owners manual recommends and you should be good to go for another 100,000.
Your wires may not need replacement. You can check them to see if resistance is within spec and if so don't bother getting rid of them. If you're just changing them out of an abundance of caution then there's nothing wrong with the OEM wires. Just don't cheap out with some kind of 'universal' wire. This is one of those cases where you'll get what you pay for.
Cheers
Gadgetjq
Postby anwagbo3000 » Sun May 04, 2008 9:05 am
Gadgetjq, thanks for your info, i will just change out my spark plugs when i change up my oil, thnaks and i guess this thread is done with
anwagbo3000
Postby onefiend » Sun May 04, 2008 9:39 am
changing plugs at 60K? just wasting your time and money...like Gadge said, they are good too 100K
2007 Camry SE V6
onefiend
Users browsing this forum: Google [Bot] and 9 guests
