SolaraGuy.com • View topic - Sensor
Sensor
Sensor
Postby Ruski » Mon Jun 09, 2008 8:39 pm
Can some one confirm where Sensor 1 Bank 1 is located ? on a I4 engine
Postby PXLpainter » Mon Jun 09, 2008 9:40 pm
I would think that would be the pre-cat sensor on the manifold before the pipe leading back to the main Cat (bank 2 sensor 2)
Postby [SMAN] » Mon Jun 09, 2008 10:29 pm
http://download.yousendit.com/56ACEA572CA403CD
PDF showing image of exactly where the sensor is (LINK ONLY GOOD FOR 7 DAYS)
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby Ruski » Tue Jun 10, 2008 3:03 pm
Thanks , now the code im getting is p2238 Bank 1 Sensor 1 , Flow Low, can this be a bad sensor ? if tried everything new gas, sea foam in the tank, tighten cap, still nothing. Now the check engine light does go over randomly but come back on
Postby Ruski » Wed Jun 11, 2008 2:14 pm
Bump any one ^^^^
Postby [SMAN] » Wed Jun 11, 2008 3:50 pm
I had posted in a sticky a chart with all the codes. Here is a PDF on everything i have in regards to code 2238, i hope it helps you diagnose your problem. http://download.yousendit.com/18A0B6DD5A0F74E6
LINK GOOD FOR 7 DAYS ONLY!!!
2004 Solara V6 SE
1996 Camry I4
[SMAN]
Postby Ruski » Wed Jun 11, 2008 6:09 pm
Not that , i already got were the sensor ..now the code im getting is p2238 Bank 1 Sensor 1 , Flow Low, can this be a bad sensor ? if tried everything new gas, sea foam in the tank, tighten cap, still nothing. Now the check engine light does go over randomly but came back on, is this normal ?
Postby [SMAN] » Wed Jun 11, 2008 6:31 pm
Read the new PDF, it has everything you need to know about code 2238, and exactly what causes it.
2004 Solara V6 SE
1996 Camry I4
[SMAN]
Postby gnegroni » Sun May 03, 2009 5:04 pm
[SMAN] wrote:Read the new PDF, it has everything you need to know about code 2238, and exactly what causes it.
Can you repost? I just "welcomed" a P2238 code after seafoaming the engine, along with other codes...however, this is my third time seafoaming in 70k miles which is weird.
gnegroni
