SolaraGuy.com • View topic - Fuel Range Off
Fuel Range Off
Fuel Range Off
Postby redgreen21 » Wed Jul 09, 2008 12:15 pm
Hello Everyone
I had joined a long time ago with my old 2001 Solara, and recently after a fender bender traded in for a 2004 White SLE. I upgrade my lights with HID from vvme and it worked great. However, When I removed the battery to place the ballast and got everything back together my fuel range seems to be off (shows a lower range value than normal). Is there an easy way to reset or should I just run to empty and refill and hope for it to recalculate better?
Thanks!
Former:2001 I4 Silver Solara
Current: 2004 White Solara SLE
redgreen21
Postby cklinh » Wed Jul 09, 2008 12:50 pm
Run to empty then refill. It'll recalculate.
cklinh
Postby redgreen21 » Wed Jul 09, 2008 12:54 pm
Thanks! Appreciate the help!
redgreen21
Postby kingkakyle » Wed Jul 09, 2008 5:57 pm
it also recalculates as u go....
so u might drive 5 miles and it will only go down one....
Postby LostSoul » Wed Jul 09, 2008 6:07 pm
does it happen to all gen 2's
it happens to mine often
LostSoul
