SolaraGuy.com • View topic - Car Alarm going off when car is started
Postby jblakely » Tue Jul 15, 2008 9:46 am
Hello,
This morning my 2004 Solara SE Sport started acting abnormally. When I turned the ignition, the car would take about a second or two longer to start and the car alarm would simultaneously go off. For a few seconds there would be a loud clicking noise (similar to that of a turn signal) coming from the dashboard left of the steering wheel.
The car would then drive normally.
However when I turn the engine off, the car alarm would go off again.
I've tried it several times and got the exact same symptoms each time.
Is this a sign that the battery/alternator needs replacing? Has anybody else here come across the same problem?
Thanks for any feedback.
jblakely
Postby 5sfe » Tue Jul 15, 2008 9:49 am
i think your alarm went bad...is it factory alarm?
5sfe
Postby jblakely » Tue Jul 15, 2008 9:51 am
5sfe: Yes
jblakely
Postby 5sfe » Tue Jul 15, 2008 9:53 am
is it the RS300 V.I.P alarm system
5sfe
Postby 5sfe » Tue Jul 15, 2008 9:55 am
if yes i need one lol okay ummm do you know were is your alarm located if yes take out open the alarm box and check if any thing is burned
5sfe
your alarm reseting its self
5sfe
Postby jblakely » Tue Jul 15, 2008 9:58 am
I'm not sure what kind it is, assuming Toyata pre-installs several types on gen 2 Solaras. I also forgot to include the fact that my clock on my dashboard is now off by several hours. I think it may be more than the alarm system. I'm not equipped to pull the alarm system out myself.
jblakely
Postby 5sfe » Tue Jul 15, 2008 9:59 am
If you want to run the car with no alarm i know how to set it up its really simple and sorry everybody for the bunch of post i made.
5sfe
Postby jblakely » Tue Jul 15, 2008 10:01 am
5sfe: I'll have to get back to you on that. I not sure if it is just the alarm system. And if it was, I don't exactly live in the best neighborhood. Thanks for the help though.
jblakely
Postby 5sfe » Tue Jul 15, 2008 10:01 am
oooo does your starter sound weak?....it could be you need a battery
5sfe
