SolaraGuy.com • View topic - U151E transmission ratios?
Postby panic » Fri Aug 15, 2008 6:41 am
I can't find the internal 5 speed auto transmission and axle ratios for my 2006 3MZ, anyone have a link or just the data?
panic
Re: U151E transmission ratios?
Postby Sebas007 » Fri Aug 15, 2008 7:15 am
panic wrote:I can't find the internal 5 speed auto transmission and axle ratios for my 2006 3MZ, anyone have a link or just the data?
Here we go
http://www.vibratesoftware.com/
Go in 1997-2008 Help File section
http://www.vibratesoftware.com/html_help/html/Toyota/2006/2006_Toyota_Camry_Solara.htm
Axle Gear Ratios
3.291
Transmission Gear Ratios
U151E
1st 4.235 (biggest Toyota gear within this reference)
2nd 2.360
3rd 1.517
4th 1.047
5th 0.756
Postby panic » Fri Aug 15, 2008 10:46 am
Hi - thanks, excellent.
I modified an Excel w/s from another engine to include this data, assumes 3.291:1 axle ratio but can be variable, input:
1. maximum RPM
2. front tire OD
Output:
1. RPM % lost and recovered at shift for 1-2, 2-3, etc.
2. RPM after upshift at shift for 1-2, 2-3, etc.
3. Minimum RPM & % recovery (from widest shift)
4. Speed in each gear in MPH
5. Overall drive ratio (selected gear ratio × axle ratio) in each gear
6. MPH per 1,000 RPM in each gear
Download it: http://victorylibrary.com/mopar/U151E.xls
panic
Postby Sebas007 » Fri Aug 15, 2008 10:51 am
very interesting. I don't understand everything by now...I will take a deeper look
Postby panic » Fri Aug 15, 2008 12:05 pm
Most likely uses:
How will my new tire size affect my shift points and speed?
Just plug in the new tire OD by over-writing the 24" figure.
How about if I shift at higher speed?
Change the RPM and all values change automatically.
panic
Postby Sebas007 » Fri Aug 15, 2008 12:08 pm
panic wrote:Most likely uses:
YeP I've got this right. The thing I wanna know is the % loss is refering to what ? Also do the F column means that shifting at 6000 RPM from 1st to 2nd will bring my RPM to 3344 ?
Postby panic » Fri Aug 15, 2008 3:23 pm
How much engine speed is lost vs. recovered (total is always 100).
Yes, the 1-2 shift recovers to 3,344 (plus some converter slippage).
panic
Postby panic » Sat Aug 16, 2008 5:20 am
Sorry, I should have known this was a mistake.
Someone already offered to sell this on Craig's list.
Anyone who downloaded this: please do not distribute it.
panic
Postby Gadgetjq » Sat Aug 16, 2008 7:22 am
Panic,
I don't know whether you'll find this useful for your purposes but check this link: http://www.gadgetjq.com/vulcan_speed_rpmcheck.htm
It's posted on my motorcycle site (thus the radio buttons at the top of the page that automatically fill in the data boxes). If you enter your gear ratio data along with tire size in the yellow boxes you'll see speed and rpm data in the green boxes. You can change tire sizes and modify (speed box) shift points to see (assuming you know the torque characteristics of your engine) where your ideal shift points would be.
Cheers
Gadgetjq
