SolaraGuy.com • View topic - Interior gauges not lighting up?
Postby behrozec34 » Mon Aug 25, 2008 10:55 pm
I turned on the car last night and non of the gauges (speedo,rev,etc) were lit up. I tried all the light settings and nothing seemed to work. I'm probably gonna end up bringing it to my audio shop, but any recommendations are much appreciated.
behrozec34
Postby ClassySolaraGuy » Mon Aug 25, 2008 11:07 pm
Check the fuse box under the steering column (nearest to where your left foot would be resting.) Look for a 10 amp fuse which will be red. I forgot which number it is under there but your manual will state it. I believe its #21 or 22. GL! 8)
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby BadAngel » Tue Aug 26, 2008 5:46 am
Also, try turning the trip odometer knob. A while back i was messing with it in the day time, and I ended up turning it all the way to the left. Later that night when i tried to go out, none of my gauges were lighting up, nor was my radio. I later realized that the dimmer is on the stem of the trip odometer and i had turned them all the way off.
So try messing with the knob on your trip odometer lol....
BadAngel
Postby System_Crash » Wed Aug 27, 2008 12:57 pm
I'd try all that and if no luck, would probly put an ignition switch in it
Pearl White 2004 Solara V6 90,000 miles
System_Crash
