SolaraGuy.com • View topic - Torque converter lock-up?
Postby panic » Tue Aug 26, 2008 7:43 am
I can't figure this out, any leads?
On the 2006 U151E (3.3), the converter locks when certain conditions are met: throttle opening, engine temp, Mph, load etc. (and unlocks when any fall out).
However: a Toyota mechanic told me that with the cruise control engaged the converter remains locked even if you hit "+" to increase speed slightly, and this is done to maximize mileage in cruise.
By comparison, if you try to maintain speed manually, you'll drop out of lock-up if you use too much gas, go up a slight hill, etc.
True or false?
panic
Postby Sebas007 » Tue Aug 26, 2008 8:16 am
Didn't know that the U151E tranny was locking-up. I thought it wasn't technologicly advanced at all. However, on cruise control I see I make much more km per liter than trying to keep my speed the same.
Postby panic » Tue Aug 26, 2008 9:49 am
http://highlanderclub.ru/files/manual/0 ... p07411.pdf
but no reference to cruise as either a fault or a positive instruction.
panic
