SolaraGuy.com • View topic - Fog light switch
Fog light switch
Fog light switch
Postby System_Crash » Mon Oct 13, 2008 11:06 am
Anyone else have to relace the multifunction switch because of the fog lamp switch "shorting" flickering the lights on and off ? I just noticed this lastnight, you turn the fogs on and push a little more forward and the lights and relay flip on and off till you release the switch of turn them off.
it's more of an annoyance right now but I know it will eventually hurt the relay/wiring/ and probly pop the light bulbs. BTW: its a dealer only item and it's $296.08 for the entire assembly and $154.59 for just the arm. :o
PS: its an 04 lara se sport
Pearl White 2004 Solara V6 90,000 miles
System_Crash
Postby Projex0 » Mon Oct 13, 2008 1:14 pm
i have notice this also the bulb indicator light in the dash no longer shows that my lights are on at night would this be covered under warranty im at 26Kso im still within it is this covered
Projex0
Postby cklinh » Mon Oct 13, 2008 1:25 pm
Projex0 wrote:i have notice this also the bulb indicator light in the dash no longer shows that my lights are on at night would this be covered under warranty im at 26Kso im still within it is this covered
"bulb indicator light"? You mean an icon on the dash that says the headlights are on? I don't remember ever seeing that...
cklinh
Postby Projex0 » Mon Oct 13, 2008 1:37 pm
yea that lil bulb indicator light icon at night weither if your head are on auto or you manualy click the headlight on it shows that its on(not drl) i remember having it but after i accedently turned the fog i pushed it just a lil bit further the fogs were flickering then the icon light went away. checked the fuses and were all good.
Projex0
Postby System_Crash » Mon Oct 13, 2008 2:38 pm
I have no bulb indicator also , don't remember if it ever had one, brights indicator still working fine.
Anyone ever experience this problem? maybe noone has noticed? everyone /w a 04 please try this and reply
System_Crash
Postby Black Bob » Tue Oct 14, 2008 11:56 am
Projex0 wrote:yea that lil bulb indicator light icon at night weither if your head are on auto or you manualy click the headlight on it shows that its on(not drl) i remember having it but after i accedently turned the fog i pushed it just a lil bit further the fogs were flickering then the icon light went away. checked the fuses and were all good.
I have an '05, nowhere on my dash is there a headlight icon other than the highbeam indicator icon. With regular headlights on (whether in 'auto' or not) the only indication your headlights are on is your dashboard lights illuminating. Of course I'm assuming there were no instrument panel design changes between '05-'06, but I don't recall seeing one in an '08 Lara I drove a month ago.
As a side note, did anybody know that there is a low wiper fluid icon? My past Fords never had that.
Black Bob
Postby cklinh » Tue Oct 14, 2008 12:01 pm
Black Bob wrote:As a side note, did anybody know that there is a low wiper fluid icon? My past Fords never had that.
Shoot, really? Maybe now, I'll stop refilling the dang reservoir everytime I wash my car for fear of running out...
cklinh
Postby Projex0 » Tue Oct 14, 2008 1:09 pm
hmm ....really i could have sworn i saw headlight indicator icon.....well i guess back on subject to the fog lights..
Projex0
Postby youngblood » Tue Oct 14, 2008 2:10 pm
I've never experienced the flickering fog lamps before. I don't recall ever seeing any indicator lamp on the instrument cluster either.
My '04 has 64K miles.
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby System_Crash » Tue Oct 14, 2008 2:33 pm
I tried playing with it some more and its seems to do it most when the fogs are on and you try to turn the headlamp switch forward (mine had a good amound of freeplay in it) but I first noticed it pushing the fog switch forward. Seems to me the previous owner was too harsh on the headlamp switch and sort of "wore out" the contacts for the headlamps. Well anywho, I guess I'll be saving some $ for the entire switch assembly :(
System_Crash
Postby silver08solara » Sat Nov 01, 2008 11:19 pm
Black Bob wrote:I have an '05, nowhere on my dash is there a headlight icon other than the highbeam indicator icon. With regular headlights on (whether in 'auto' or not) the only indication your headlights are on is your dashboard lights illuminating. Of course I'm assuming there were no instrument panel design changes between '05-'06, but I don't recall seeing one in an '08 Lara I drove a month ago.
I have an '08 and I do have a headlights on indicator in my car.
No modern (Post 1994) US Ford cars have a light for wiper fluid level except the Lincoln Continental 1995 and later and then it was a warning in the multifunction on board computer, not a light. Most other cars have such a light (my 1995 Chrysler Lebaron GTC even had one).
Since that is not an item that most owner's routinely check, it is probably a good idea.
silver08solara
Postby Projex0 » Sat Nov 01, 2008 11:51 pm
get a quick pic of it ^^
Projex0
Postby Taido » Sun Nov 02, 2008 12:16 pm
Just high beams that I've seen. Check the manual.
Taido
Audiophiliac
Audiophiliac
Postby silver08solara » Mon Nov 03, 2008 12:34 pm
Projex0 wrote:get a quick pic of it ^^
I'll post them here:
The green symbol below the oil warning lamp is the lights on indicator (it is only on when the tail lamps are on. It comes on if you turn them on manually or let the automatic system do it for you.)
The blue light at the top left is the high beam indicator.
The lights on indicator must be something that is exclusive to the '08 Solara models.
Last edited by silver08solara on Mon Nov 03, 2008 1:53 pm, edited 2 times in total.
silver08solara
Postby Projex0 » Mon Nov 03, 2008 1:09 pm
i knew there was a light indicator
Projex0
