SolaraGuy.com • View topic - Maint light blinking
Postby lightguypro » Wed Oct 15, 2008 5:44 pm
So I noticed the other day that when i first start the car this light blinks for about 5 sec's or so. What could it be..tried to go to autozone and they dont read codes no more..do i got to take to dealer to find out?
all stock..only thing i did was re-route the air line for that flap to stay open on the intake.
04 v6 sle
thanks everyone for there insight
Da Lightguy
2004 v6 sle
lightguypro
Postby gnegroni » Wed Oct 15, 2008 5:54 pm
If its the maintenance light, I think your 5k oil change interval is coming up (stays on after 5k). Nothing to be worried about. If you have a CHECK ENGINE LIGHT (CEL), then you'd take it to Autozone.
Funny thing, but my Maint light went off without it being reset. Funny...
gnegroni
Postby Dawgz » Wed Oct 15, 2008 5:55 pm
Do u have a laptop? if so, ur cheap option is this
http://cgi.ebay.com/ebaymotors/NEW-ELM3 ... 911.c0.m14
I just baught the same unit from that seller, came in the end of 2 weeks from Hong Kong...and works real well.
Apart from that, u can try to find other places that read codes, but most places that "charge" to read the code, charge upwards to 50+...So the 28 bux ud spend on ebay for ur own reader pays for itself in its first use.
GL!
Postby lightguypro » Thu Oct 16, 2008 6:00 pm
so how do you reset the light after you change your oil?
Da Lightguy
2004 v6 sle
lightguypro
Postby Down2TheC » Sat Oct 18, 2008 5:29 am
That process is in you manual. If you don't have that it's in here several times. But I did it recently and I believe its something like:
1. tap the trip odo button until you're looking at the main odometer.
2. Pull the key out.
3. Push the trip reset button and hold it.
4. Put the key in and turn the ignition to "ON"
5. Keep holding the trip reset btn and in 5 seconds the Maint light should blink 3 times. Then you can release the btn and you're reset.
Down2TheC
Re: Maint light blinking
Postby Gadgetjq » Sun Oct 19, 2008 5:38 am
lightguypro wrote:So I noticed the other day that when i first start the car this light blinks for about 5 sec's or so. What could it be..
Check page 136 of your owners manual. After you've done the oil change here's the reset procedure:
1. Turn your ignition on and make sure the odometer is showing total vehicle miles (not one of the trip meters)
2. Turn the ignition off and push the trip/odometer reset button
3. While holding the button turn the ignition on and watch the mileage display
4. When the display reads 000000 (it could take a few seconds) you've reset the counter.
Cheers
Gadgetjq
Postby Down2TheC » Sun Oct 19, 2008 6:17 am
What he said. 4500 is blinking at start up, 5000 miles you get a solid.
Down2TheC
Postby Black Bob » Mon Oct 20, 2008 10:52 pm
Have any of us gave it any further thought to the maintenance light coming on for oil changes being different? Some of us are getting the light at 3k miles, others are getting it at 5k miles. Are the I-4s and V-6s differently timed for oil changes?
Black Bob
Postby Gadgetjq » Tue Oct 21, 2008 6:39 am
Black Bob wrote:Some of us are getting the light at 3k miles, others are getting it at 5k miles. Are the I-4s and V-6s differently timed for oil changes?
What does your owners manual say? Mine (V6) specifically says 4500 for the temporary blinking light and 5000 for it to come on solid which is exactly when those indicators come on. It may be different for the 4 cylinder. If the Gen I cars have the same indicator there may be a difference but this thread is about the '04 and later cars so wouldn't apply.
Cheers
Gadgetjq
Postby Taido » Tue Oct 21, 2008 1:49 pm
My straight 4 maint. light started blinking at 4500 so there goes that theory.
Taido
Audiophiliac
Audiophiliac
