SolaraGuy.com • View topic - Solaras "brain"
Solaras "brain"
Solaras "brain"
Postby fujiwara » Tue Nov 04, 2008 12:31 pm
Hey guys.
Does anyone know, how can i find the cars brain. I was told that it's somewhere in the center console....is that correct?
Maybe some of you know better, I wouldn't like to take everything a part.
Thanks in advance.
fujiwara
Postby Jakecallun20 » Tue Nov 04, 2008 1:08 pm
The ECU is located behind the glove box.
Postby TLMNICK » Tue Nov 04, 2008 1:48 pm
I hope you are referring to the ECU.....which is behind the glove box as Jakecallun20 mentioned.
The only thing that might be under the center console is the factory security module....or "brain"
TLMNICK
Postby youngblood » Tue Nov 04, 2008 2:28 pm
The yaw sensor would be right in the middle of the car (if you have the stability control package). I wouldn't call that the 'brain' though.
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby NeFaRiOuS_SLE » Wed Nov 05, 2008 1:00 am
Yaw sensor? For a second there I thought that you were talking about planes... But then again my brain kinda farted (not to mention I forgot what said part was, and I don't have stability control in my car).
ECU = Behind glovebox
ABS and/or airbag controller (forgot... I'll have to look at my Haynes Manual) = Behind ashtray
Factory alarm sensor = Below center console storage
Yaw sensor = Uhh... What he said.
Postby fujiwara » Wed Nov 05, 2008 7:07 pm
Hmm...I'll take a look. It's called "aju" in Estonian which means "brain" in English. I thought it's the right word for it but it seems i was wrong. I'll take a look if the ECU is the thing i'm looking for, thanks for replies guys :wink:
fujiwara
Postby Down2TheC » Thu Nov 06, 2008 10:58 pm
ECU take in many measurements and sensor readings and controls throttle, fuel injections, and many safety/efficiency functions. There's a separate one for body features like windows and such. But if it's engine related, you want the ECU.
Down2TheC
Postby gnegroni » Wed Nov 12, 2008 7:35 am
...this thread and many others keep making me think the Solaraguy comunity is simply awesome! You guys are great to work with!
gnegroni
Users browsing this forum: Google [Bot] and 10 guests
