SolaraGuy.com • View topic - problem with my solara...
Postby pepowdylan » Wed Nov 19, 2008 8:13 pm
ok so this morning i turn on my car... im rushing to school... so i rev up to go alittle faster... it hits 3000 rpms and wont rev anymore.... and now it doesnt want to go into any more gears it feels like ( i really dont know alot bout cars but) all i know is at 3000 rpms my car rattles and its not a good feeling... so then my check engine light starts flashing... then its on now. and it flashes when i try to get it to go past 3000 rpms.
whats wrong? im going to autozone soon for the codes
pepowdylan
Postby Midias » Wed Nov 19, 2008 8:57 pm
Well without codes I would guess it is one of the following. But seriously check all of your spark plug wires.
P0100 – Mass Airflow (MAF) sensor circuit malfunction
· Open or short in MAF sensor circuit
· MAF sensor malfunction
· PCM malfunction
P0101 – Mass Airflow (MAF) circuit range/performance problem
P0105 – Manifold Absolute Pressure (MAP) Sensor circuit malfunction
· Open or short in MAP sensor circuit
· MAP sensor malfunction
· PCM malfunction
P0106 – Manifold Absolute Pressure (MAP) sensor malfunction
· Defective MAP sensor
· Loose, torn or missing vacuum line
P0110 – Intake Air Temperature (IAT) sensor circuit malfunction
· Open or short in IAT sensor circuit
· IAT sensor malfunction
· PCM malfunction
P0115 – Engine Coolant Temperature (ECT) sensor circuit malfunction
· Open or short in ECT sensor circuit
· ECT sensor malfunction
· PCM Malfunction
P0116 – Engine Coolant Temperature (ECT) circuit range/performance problem
· Cooling system problem
P0120 – Throttle/Pedal Position Sensor (TPS) circuit malfunction
· Open or short in TPS circuit
· TPS malfunction
· PCM malfunction
P0121 - Throttle/Pedal Position Sensor (TPS) range/performance problem
· TPS malfunction
P0125 – Insufficient Coolant Temperature closed loop fuel control (non-California)
· Open or short in heated oxygen sensor (bank 1, sensor 1) circuit
· Heated oxygen sensor (bank 1, sensor 1) malfunction
· PCM malfunction
P0125 – Insufficient Coolant Temperature closed loop fuel control (California)
· Open or short in air/fuel (A/F) sensor circuit
· A/F sensor malfunction
· PCM malfunction
P0128 – Thermostat Malfunction
· Thermostat malfunction
P0130 – Heated Oxygen Sensor Circuit Malfunction (bank 1, sensor 1)
· Heated oxygen sensor malfunction
· Fuel trim malfunction
P0133 – Heated Oxygen Sensor Slow
P0135 - Heated Oxygen Sensor Heater Circuit Malfunction (bank 1, sensor 1)
· Open or short in heated oxygen sensor heater circuit
· Heated Oxygen sensor heater malfunction
· PCM malfunction
P0136 - Heated Oxygen Sensor Circuit Malfunction (bank 1, sensor 2)
P0141 - Heated Oxygen Sensor Heater Circuit Malfunction (bank 1, sensor 2)
· PCM malfunction
P0150 – Heated Oxygen Sensor Circuit Malfunction (bank 2, sensor 1)
P0153 - Heated Oxygen Sensor Circuit Slow Response (bank 2, sensor 1)
P0155 - Heated Oxygen Sensor Heater Circuit Malfunction (bank 2, sensor 1)
· PCM malfunction
P0171 – System too lean
· Loose air intake hose or duct
· Incorrect fuel line pressure
· Obstruction in injector
· MAP or MAF sensor malfunction
P0172 – System too rich
· Leaking injector
· MAP or MAF malfunction
P0174 - System too lean (air/fuel lean malfunction, bank 2)
· Same as P0171
P0175 – System too rich (air/fuel rich malfunction, bank 2)
· Same as P0172
P0300 – Random or Multiple Cylinder Misfire Detected
· Ignition system malfunction
· Injector malfunction
· EGR malfunction
· Incorrect compression pressure
· Incorrect valve clearance
· Incorrect valve timing
P0301 – Cylinder no. 1 Misfire Detected
· Same as P0300
P0302 – Cylinder no. 2 Misfire Detected
· Same as P0300
P0303 – Cylinder no. 3 Misfire Detected
· Same as P0300
P0304 – Cylinder no. 4 Misfire Detected
· Same as P0300
P0305 – Cylinder no. 5 Misfire Detected (V6 models)
· Same as P0300
P0306 – Cylinder no. 6 Misfire Detected (V6 models)
· Same as P0300
P0325 – Knock Sensor 1 Circuit Malfunction (bank 1, V6 models)
· Open or short in knock sensor 1 circuit
· Loose knock sensor 1
· PCM malfunction
P0330 – Knock Sensor 2 Circuit Malfunction (bank 2, V6 models)
· Open or short in knock sensor 2 circuit
· Loose knock sensor 2
· PCM malfunction
P0335 – Crankshaft Position Sensor A Circuit Malfunction
· Open or short in crankshaft position sensor circuit
· Crankshaft position sensor malfunction
· Starter Malfunction
· PCM malfunction
P0340 – Camshaft Position Sensor Circuit Malfunction
· Open or short in camshaft position sensor circuit
· Camshaft position sensor malfunction
· Starter malfunction
· PCM malfunction
P0401 – EGR Insufficient Flow Detected (4-Cylinder engine)
· EGR valve stuck closed
· Open or short in VSV circuit for EGR
· Vacuum or EGR hose disconnected, torn or missing
· EGR VSV stuck open or closed
· PCM malfunction
P0401 – EGR Insufficient Flow Detected (V-6 engine)
· Open or short in EGR gas temperature sensor circuit
· EGR gas temperature sensor malfunction
· EGR VSV malfunction
· Vacuum control valve malfunction
· Vacuum hose disconnected or blocked
· PCM malfunction
P0402 – EGR Excessive Flow Detected (4-Cylinder engine)
· EGR valve stuck open
· Vacuum or EGR hose connected to wrong pipe
· PCM malfunction
P0402 – EGR Excessive Flow Detected (V-6 engine)
· Short in EGR VSV circuit
· Open or short in EGR valve position sensor circuit
· EGR valve position sensor malfunction
· PCM malfunction
P0420 – Catalyst System Efficiency Below Threshold (4-Cylinder engine)
· Three-way catalytic converter malfunction
· Open or short in heated oxygen sensor circuit (bank 1, sensor 2)
· Heated oxygen sensor malfunction (bank 1, sensor 2)
· Open or short in heated oxygen sensor circuit (bank 1, sensor 1) or A/F sensor 2 circuit
P0420 – Catalyst System Efficiency Below Threshold (V-6 engine)
P0440 – EVAP System Malfunction
· Vapor pressure sensor malfunction
· Fuel tank cap cracked, damaged or incorrectly installed
· Vacuum hose blocked, cracked, torn or disconnected
· Hose or tube blocked, cracked, torn or disconnected
· Fuel tank damaged
· Charcoal canister damaged
P0441 – EVAP Control System - incorrect purge flow
· Open or short in VSV circuit for EVAP
· VSV for EVAP
· Open or short in vapor pressure sensor circuit
· Open or short in VSV circuit for vapor pressure sensor
· Malfunction in VSV for vapor pressure circuit
· Vacuum hose blocked, damaged, or disconnected
· Charcoal canister malfunction
P0442 – EVAP System - small leak detected
· Same as P0440
P0446 – EVAP System - vent control malfunction
· Same as P0441
P0450 – EVAP System - pressure sensor malfunction
· PCM malfunction
P0451 – EVAP System – pressure sensor range/performance problem
· Same as P0450
P0500 – Vehicle Speed Sensor Malfunction
· Open or short in speed sensor circuit
· Vehicle speed sensor malfunction
· Instrument cluster malfunction
· PCM malfunction
P0505 – Idle Control System Malfunction
· Idle air control (IAC) valve stuck or closed
· Open or short in IAC valve circuit
· Open or short in A/C switch circuit
· Air intake duct or hose loose
· PCM malfunction
Postby [SMAN] » Wed Nov 19, 2008 10:19 pm
The solara ECU has a "Limp home" mode where it won't shift into high gears or rev past around 3,000 RPM to save the engine. I put a dead battery into my car one time cause i thought it was still good and drove down the street to charge it and i went into the same situation.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby youngblood » Thu Nov 20, 2008 4:42 pm
I put my dad's Z3 in limp home mode once because I left the oil fill cap off and drove it on the highway for 20 minutes. By the end of the trip, it was exhibiting the same symptoms you describe- because it was pretty low on oil.
Obviously there are a lot of reasons a car will go 'limp'.
Good luck in the diagnosis!
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby pepowdylan » Thu Nov 20, 2008 5:24 pm
is it ok to drive for the weekend till i have time on monday to fix
pepowdylan
Postby [SMAN] » Thu Nov 20, 2008 6:39 pm
pull the battery and reset the ecu. If there really is a problem, it will go into limp home mode again.
2004 Solara V6 SE
1996 Camry I4
[SMAN]
Postby youngblood » Fri Nov 21, 2008 12:51 pm
[SMAN] wrote:pull the battery and reset the ecu. If there really is a problem, it will go into limp home mode again.
^^^^^^^what he said^^^^^^^^
You run the risk of doing serious damage to your ride if you drive it with the CEL flashing.
youngblood
