SolaraGuy.com • View topic - battery draining..? odometer
Postby lightguypro » Sun Dec 07, 2008 2:04 pm
Hello, Noticed the past couple of days seems if my car is sitting over night that the battery seems really weak when starting it..it turns over fine..just takes a little more to turn over and the warning lights that come on are flashing like if the battery dead when trying to start it..
anyhow..noticed today that my odometer stays on the whole time after car is shut off and keys are out and doors locked...is this normal?
would cold weather be draining the battery?
thanks for all your help in advance...
Da Lightguy
2004 v6 sle
lightguypro
Postby kingkakyle » Sun Dec 07, 2008 2:16 pm
is it the stock battery?
it could just be dying and needs to be replaced
and yes if i remember correctly the odometer stays on
Postby gnegroni » Sun Dec 07, 2008 2:37 pm
Nice to know...
How old is the battery?
gnegroni
Postby lightguypro » Sun Dec 07, 2008 5:18 pm
Not sure how old the battery is..I purchased the car used this past summer. Bet its old..i been so busy at work just sleep and work..thats all I can do..I have a day off tomorrow I will change it and see what it does
Da Lightguy
2004 v6 sle
lightguypro
Postby kingkakyle » Sun Dec 07, 2008 7:01 pm
go to an autozone and they should be able to test it for u for free
Postby youngblood » Tue Dec 09, 2008 3:30 pm
I didn't think the odo would stay on all the time- I'll check when I go home from work.
This post reminds me of another SG who had a bad ignition switch that was causing the lights and other things to stay on. I would be checking into that if you find your battery is good (or if you replace the battery only to find that the problem persists).
Good luck!
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby [SMAN] » Tue Dec 09, 2008 8:23 pm
the odo doesn't stay on all the time. It has a timer on it but basicly it's the first to turn on and the last to turn off. It will turn on when you open the drive door and i think even when unlocking the car. It will stay on as long as the keys are in the ignition (even if it's in off).
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
