SolaraGuy.com • View topic - Thumping noise tsb
Thumping noise tsb
Thumping noise tsb
Postby someazn » Tue Dec 30, 2008 8:39 pm
Can anyone repost the tsb? I want to print it out and take it to the dealer. It just happened to my 05 and its annoying as hell. Thanks.
It's suppose to be here: http://www.alldata.com/tsb/Toyota/11405 ... 6/261.html
but I can't load it?
someazn
Postby ---CAMRAZY--- » Tue Dec 30, 2008 9:40 pm
Thumpping noise from where?
Postby someazn » Tue Dec 30, 2008 10:12 pm
I hear it in the right rear, sometimes centerish, not sure but if sounds like something is rolling around clanking stuff, sort of like wood hitting metal thump sound
someazn
Postby Dawgz » Tue Dec 30, 2008 10:13 pm
someazn wrote:I hear it in the right rear, sometimes centerish, not sure but if sounds like something is rolling around clanking stuff, sort of like wood hitting metal thump sound
strut mount?
Postby someazn » Tue Dec 30, 2008 10:23 pm
im not sure, i thought it was the trd rsb, had that relubed today and the sound is still there, would the tsb not apply to my 05? The sound is really loud, and its getting annoying
someazn
Postby someazn » Tue Dec 30, 2008 10:28 pm
it might actually be the strut mount since its part of the tsb, I'm just wondering if anyone has the tsb and can repost it so that way i can print it and bring it to the dealer, thanks
SU002-06 TSB Date: 2/21/2006
Component: STRUT MOUNT:SUSPENSION STRUT
Summary: SUSPENSION - REAR SUSPENSION THUMPING NOISE ON BUMPS
someazn
Postby someazn » Tue Dec 30, 2008 11:08 pm
im also out of warranty, any advice on what i should do?
someazn
Postby gnegroni » Tue Dec 30, 2008 11:24 pm
someazn wrote:im also out of warranty, any advice on what i should do?
Well, read the TSB. I don't have the TSB in my hands, but try to perform the same TSB tasks yourself, or with your mechanic. Several people here have done so with excellent results...I think it was the left pull Issue TSB.
As for the thumping noise, my rear struts were replaced. The dealer never admitted as to whether the problem was TSB related or not. They told me one of the shocks was leaking...blah!
gnegroni
Postby someazn » Tue Dec 30, 2008 11:29 pm
funny this stuff happens right when my warranty ends...
someazn
Postby Black Bob » Wed Dec 31, 2008 2:25 am
Haha, that's funny timing of this thread. I had a thumping noise in the back today. Turned out to be a gallon of bleach I totally forgot about. With the way I drive I'm lucky my trunk isn't spotted like a Dalmation right now.
Anywayz, did you check to make sure nothing is kicking around loose in the spare tire well?
Black Bob
Postby someazn » Wed Dec 31, 2008 2:46 am
yea, i took the spare tire out and everything from the trunk and that sound is still there
someazn
Postby someazn » Thu Jan 01, 2009 1:33 am
so what should i do, replace the strut mounts?
someazn
Postby gnegroni » Thu Jan 01, 2009 9:59 am
someazn wrote:so what should i do, replace the strut mounts?
Did you read the TSB? I'm not sure if it called for immediate replacement.
gnegroni
Postby someazn » Fri Jan 02, 2009 5:06 pm
thanks for the help guys, the problem is now fixed, it was a loose bolt somewhere near where the trd rsb mounts to the hanger...weird :o
someazn
Postby gnegroni » Fri Jan 02, 2009 5:42 pm
someazn wrote:thanks for the help guys, the problem is now fixed, it was a loose bolt somewhere near where the trd rsb mounts to the hanger...weird :o
Glad you could work it out! :)
gnegroni
