SolaraGuy.com • View topic - Can't shift up
Can't shift up
Can't shift up
Postby Reigns » Mon Jan 19, 2009 9:26 am
I have an 05 SLE w/v6 engine and automatic transmission.
The little "+/-" on the gear shift left from "D" that is supposed to let us select our own gear in drive doesn't shift up for me. Even if I use it to shift down, I can't use it to shift back up.
Reigns
Postby fzzyrn » Mon Jan 19, 2009 10:36 am
the thing about that is that it doesn't really control the gear. It just lets you set the maximum gear that the car will shift into. If it's set at 4, you won't start at 4 from a dead stop. It's essentially automatic with a little more control.
Usually, if you're approaching the shift RPM, which is something like 3.5K, it should shift in good time. If you're above the shift point, it should shift immediately, but may be a bit rough.
fzzyrn
Postby youngblood » Mon Jan 19, 2009 2:53 pm
fzzyrn wrote:the thing about that is that it doesn't really control the gear. It just lets you set the maximum gear that the car will shift into. If it's set at 4, you won't start at 4 from a dead stop. It's essentially automatic with a little more control.
Excellent explanation^^^^^^^^^^^^^^^^^^^+1
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby Black Bob » Mon Jan 19, 2009 5:32 pm
....or as some of us northerners have learned, when it's -25°F outside the transmission ain't too keen on upshifting right away. :-?
Black Bob
Postby fzzyrn » Mon Jan 19, 2009 6:54 pm
also, i like to ease off the gas as the engine approaches shift rpm. Luckily, toyota has made it so the gear shifts at the speeds of majority for most streets. In short, 1st to 2nd at 20mph, 2nd to 3rd and 35mph, 3rd to 4th at 50ish, 4th to 5th at some highish speed (i haven't quite experimented with the last two).
fzzyrn
