SolaraGuy.com • View topic - Window Problems
Window Problems
Window Problems
Postby solaraboy » Fri Mar 06, 2009 1:52 am
What happened was something broke off inside the door so yada yada yada to make the long story short, i went to the stealership to have it checked and as usual they wna charge me $300+ and said its not covered by my ext warranty, man i was pissed so i fixed it myself. If you guys got the same problem, heres the picture if it would help.
this part came off which caused the misalignment of the window
solaraboy
Re: Window Problems
Postby [SMAN] » Fri Mar 06, 2009 6:44 am
solaraboy wrote:What happened was something broke off inside the door so yada yada yada to make the long story short, i went to the stealership to have it checked and as usual they wna charge me $300+ and said its not covered by my ext warranty, man i was pissed so i fixed it myself. If you guys got the same problem, heres the picture if it would help.
Did you actualy crack the glass? If you didn't all that part is a bolt with a felt cup around it to act as a bump stop for the window. I've had my passenger side one come loose a few times, and i jsut tightened it back up. If you still have a perfectly good hole in your glass, talk to reggie about getting the replacement part if the dealership is trying to charge too much.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby solaraboy » Fri Mar 06, 2009 12:01 pm
Nothn wrong w the glass just the bump stops came loose so i used some loctite threadlocks so it wont happen again, Btw thanks.
solaraboy
