SolaraGuy.com • View topic - Sway bar links: Gen1 vs. Gen2
Postby [SMAN] » Wed Mar 25, 2009 4:55 pm
My rear sway bar links are leaking grease, that means it's time to change them. Are the gen1 links different from the gen2? They look allmost identical. And what are people's take on the cheap ebay ones?
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby [SMAN] » Fri Mar 27, 2009 8:49 am
No one has anything to say about this?
2004 Solara V6 SE
1996 Camry I4
[SMAN]
Postby akora12 » Fri Mar 27, 2009 10:58 am
I don't know about the compatibility between gen 1 and 2, but I do know it's not worth it to go OEM. I ended up cutting my frozen ones off when I installed my first installation, and did the same a year later when I installed my coilovers. Don't get endlinks that use an allen wrench to tighten, it's a terrible design.
I got some moog links that are far superior to OEM. They did away with the allen socket, are much beefier, and can also be refilled with grease if the joint starts going bad.
