SolaraGuy.com • View topic - How do you remove the rear rotors?? =/
Postby DevilzAdovocate » Fri Apr 17, 2009 3:08 pm
Am trying to take them off but something is keeping them on and am not sure if it has some type of pin system or there just rusted on? I tried pressing the pin type things on the inside but nothing. It doesn't even loosen it a bit?
Anyone? any help or has anyone done this????
thanks for any help!
DevilzAdovocate
Postby ThatVietGuy » Fri Apr 17, 2009 3:14 pm
Lightly hammer the center of the rotor.
Or there should be holes where you can thread bolts in to pop the rotor off.
ThatVietGuy
Postby DevilzAdovocate » Fri Apr 17, 2009 3:19 pm
mind it is a gen2, not to sure if its any different then a gen1. I tried banging them lightly and full on banging!! yes, am aware of the damage i my be causing. But thats not working at all! If thats the case, there rusted pretty bad!!! But am not so sure since am getting no where banging them and am messing with some pins on the inside of the rotor but that also does nothing. So am lost??? i need to replace all the studs, 2 broke off already and mights as well replace them all so i dont have to do this in the future if it comes up
DevilzAdovocate
Postby cklinh » Fri Apr 17, 2009 3:25 pm
cklinh wrote:Just another tidbit to add to the pile...
One of my two trips during the install was to find bolts to help remove the rear rotors. Even though I released the parking brake mechanism, my rotors were stuck, possibly due to rust. Luckily, there are two holes on the rotor itself that you can use to "push" the rotor off of the assembly.
The bolts I used were 5/16" (2" long, although you're only screwing it in about 1/4"). They were a tight fit, and took a few tries before the threads actually got lined up. It took about 15 minutes after I got the right sized bolts (kinda wished I had given up on pounding on the rotors earlier... would have saved two hours).
cklinh
Postby youngblood » Sat Apr 18, 2009 7:22 am
DevilzAdovocate wrote:mind it is a gen2, not to sure if its any different then a gen1. I tried banging them lightly and full on banging!! yes, am aware of the damage i my be causing. But thats not working at all! If thats the case, there rusted pretty bad!!! But am not so sure since am getting no where banging them and am messing with some pins on the inside of the rotor but that also does nothing. So am lost??? i need to replace all the studs, 2 broke off already and mights as well replace them all so i dont have to do this in the future if it comes up
I have to ask how you managed to break off two studs?!
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby drewcrane » Sat Apr 18, 2009 9:26 am
me too!
"its a vanishing point thing you wont understand"
drewcrane
Location: 13.7 sec.s @bandimere ,5800 ft above sea level
