SolaraGuy.com • View topic - A/c
A/c
A/c
Postby Maniax » Thu May 14, 2009 9:37 pm
My ac light it lighting up and i was going to see if i could fix the problem myself for cheaper then the dealer.I would believe the freon would be low or have a leak.Any other ideas?
Maniax
Postby kingkakyle » Thu May 14, 2009 10:24 pm
on the dash? i didn't know there was an ac light there lol
good luck
Postby D-money » Thu May 14, 2009 10:26 pm
when the button lights up it usually means its ON. LOL!!!!!
D-money
Postby Maniax » Fri May 15, 2009 12:54 am
No it is blinking..It will light up then start to blink
Maniax
Postby GzNutz » Fri May 15, 2009 4:40 am
Maniax wrote:No it is blinking..It will light up then start to blink
Last summer that happened to me. During a 45 min ride the a/c would work great for about 30 mins, then it would go from a green light on the ac button to a blinking yellow light. After I shut the ac off for a few mins I could turn it back on and have it green once again. I have no idea what was the problem. But it only occured on 100+ degree days.
Postby NightRider » Sat May 16, 2009 12:28 am
That's weird. I would have never thought that the a/c light would blink.
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby SpeedySolara » Sat May 16, 2009 12:55 am
I had the same issue on my 99 SLE
SpeedySolara
Postby [SMAN] » Sat May 16, 2009 8:45 am
Ok so the air conditioning section of the FSM has some info on this:
Code: Select all
The air conditioning ECU is equipped with a selfdiagnosis
function. If there is a malfunction in the
system, it stores the DTCs (Diagnostic Trouble
Codes) in its memory and the air conditioning
switch indicator blinks.
Code: Select all
Compressor Lock Sensor Circuit
This sensor sends 1 pulse per engine revolution to the ECM.
If the ratio between engine and compressor speed deviates 20 % or more in compression to normal
operation, the ECM turns the cooler compressor off and the indicator blinks at approximately 1 second
intervals.
there is a procedure to read the dtcs and see what test is failing in the FSM.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby NightRider » Sat May 16, 2009 9:22 am
Good find there SMAN.
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby ChrissyD123 » Sat May 16, 2009 9:34 am
LOL. Damn those New Solaras :roll:
</SolaraGirl>
{15inch JL sub w/ 1000 JL Watt Amp.... Stock engine, but clean Lara}
ChrissyD123
Postby youngblood » Sat May 16, 2009 1:55 pm
SpeedySolara wrote:I had the same issue on my 99 SLE
ChrissyD123 wrote:LOL. Damn those New Solaras
Whatev............................. :roll: :)
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby youngblood » Sat May 16, 2009 1:58 pm
NightRider wrote:Good find there SMAN.
^^^^^^x2
youngblood
Postby GzNutz » Sat May 16, 2009 4:55 pm
Could the deviation causing the error possibly be a slipping belt?
Postby [SMAN] » Sat May 16, 2009 5:10 pm
GzNutz wrote:Could the deviation causing the error possibly be a slipping belt?
Could be a lot of things. The belt could be slipping, but those are usualy low friction setups so more likely, the clutch isn't fully engaging on the pully, or it could be a circuit board issue. Read the DTCs out of the system and see what they say.
2004 Solara V6 SE
1996 Camry I4
[SMAN]
Postby 5sfe » Sat May 16, 2009 9:36 pm
no, rest: turn off and on your a/c, its should be fixed, this has happen to me, everytime my solara see's a puddle.... its caused by a small shortage, mostly happens to the 4cylinder solara's with no splash gaurd
5sfe
