SolaraGuy.com • View topic - Brake booster on 2004 V6 SLE?
Postby gfryhtsn » Mon May 25, 2009 12:55 pm
I bought a can of sea foam so I could put it in the brake booster, and low and behold I cant find the break booster on this car! Does anyone have any input on this? Thanks...I did a search and couldnt find anything!
Also My car has sluggish shifting every now and then sometimes when cold, and sometimes when warmed up. Dealer charged 350 for the flash of the engine computer, but it still does it...I have read that this seems to be a common problem...Has everyone just learned to live with this? Thanks
gfryhtsn
Postby Biggi_e » Mon May 25, 2009 8:44 pm
there is a TSB print out you can try and bring to your dealer. (see if they will do the re-flash for free depending on what your mileage and warranty is)
i do get the jerk going on and it gets annoying at times but also depends on how you drive. do you have a leadfoot?
Postby gfryhtsn » Mon Jun 01, 2009 6:45 pm
Not usually...every now and then I do...But the jerk is usually when im taking off slowly...and when im accelerating like between 40-50 it jerks...
gfryhtsn
Postby Ilovemylara » Mon Jun 01, 2009 6:49 pm
the brake booster is located on the firewall right behind your intake tube. I found this pic on google, and although its a i4, the layout is the same.Image
Postby Ruski » Mon Jun 01, 2009 10:03 pm
the braker booster on the gen 2 is in the same spot as gen 1s upper drivers side. on the firewall . you cant miss it
Postby NightRider » Tue Jun 02, 2009 5:04 pm
You do the Seafoam yet?
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby Ruski » Tue Jun 02, 2009 5:59 pm
me? yes i have
Postby NightRider » Thu Jun 04, 2009 3:11 pm
You think I should do it mine? Car has 67K on it. Pretty sure it has never been done on my car. But after every oil change I get a can of seafoam and pour the whole can into my gas tank before I fill up.
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby youngblood » Fri Jun 05, 2009 5:47 pm
NightRider wrote:You think I should do it mine? Car has 67K on it. Pretty sure it has never been done on my car. But after every oil change I get a can of seafoam and pour the whole can into my gas tank before I fill up.
Man, there is no way you should need seafoam with that new of a car and so few miles. Faghettabottit! :drinking:
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby Ruski » Sun Jun 07, 2009 6:58 pm
i sea-foamed at 65k and had a little bit of smoke felt a little better throttle response. but i also changed out my plugs and recharged K&N filter and cleaned throttle body
Users browsing this forum: Google [Bot] and 14 guests
