SolaraGuy.com • View topic - What is the real correct way to rotate tires?
Postby lambition » Sat Sep 05, 2009 4:08 pm
When I roate tires, I usually just do front to rear, and rear to front with no corssing.
Not because I believe this is best, but just because I'm too lazy. LOL (Didn't want to have more than 2 wheels off at the same time.)
I did a google search to find what is the best way, and I found eveybody has different opinions.
Most suggested that
Front to rear, and rear to front with cross for front wheel drive.
Front to rear with cross, and rear to front for rear wheel drive.
Small number of people suggested X pattern.
And most other people suggested front to rear and rear to front without crossing and that radial tires should never be crossed because doing so will split the wires inside tire. (Tires should be rotating same direction they were installed when new, even for non-directional tires.)
Does anyone know if switching rotaion of tires will really split the wires inside?
Also anyone know theories behind all different rotation methods?
lambition
Postby GreenSolara01 » Sat Sep 05, 2009 4:19 pm
FWD Front tires go back, Back tires cross.
GreenSolara01
Postby 1gSE » Sat Sep 05, 2009 4:34 pm
GreenSolara01 wrote:FWD Front tires go back, Back tires cross.
:agree: I worked at a tire/custom wheel shop for 3 years and thats how we did it. Eventually everything would be everywhere
Solara-M62 @ 5.5psi
1gSE
Postby lambition » Sat Sep 05, 2009 5:29 pm
Do you know any theory behind this method? That is what I really want to know.
There are more than few people recommending against this.
Saying "criss crossing rotation will cause the belts inside the tire to separate poss ably causing a blowout"
Do you know if there is any truth behind this?
lambition
Postby akora12 » Sat Sep 05, 2009 5:59 pm
The method listed above has been the tride and true for years. My dad and uncle have been doing that on their hotrods since the 60's. Unless you have directional tires, I'd stick with it.
Postby 1gSE » Sat Sep 05, 2009 6:07 pm
The only belt separations I dealt with were manufacturer defects. Rotating them the way GreenSolara01 mentioned will have a more even wear across all 4 tires
http://www.tirerack.com/tires/tiretech/ ... ?techid=43
Solara-M62 @ 5.5psi
1gSE
Postby lambition » Sat Sep 05, 2009 7:25 pm
1gSE wrote:The only belt separations I dealt with were manufacturer defects. Rotating them the way GreenSolara01 mentioned will have a more even wear across all 4 tires
So, do you believe it is safe to say belt seperation by cross rotating tires is a myth?
According to tirerack and many other tire related web sites, it seems changing direction of roation of a tire does not cause any problem unless it is a directional tire.
lambition
Postby Black Bob » Wed Sep 09, 2009 10:23 am
Criss-crossing aids in keeping tire wear even not just from tire to tire but also from left to right of each tire. With today's rubber compound and belt technology you should not see any belt separation on any tire unless you're hella speeding or your tires are hella old. In other words--cross rotation does not lead to belt separation and should prevent it. Directional tires are based off tread design (mostly)--wrong direction equals less traction and poor water channeling--no blowouts should occur if put on wrong.
Although Tirerack is a decent business remember they are trying to sell you tires (like oil change shops are selling 3,000 mile synthetic oil changes), so some info you read is going to be biased.
Black Bob
Postby HomeboyMI » Tue Sep 22, 2009 8:06 am
Page 286 of your Owners Manual suggests you rotate your tires front to rear without any criss crossing.
HomeboyMI
Postby aleki2424 » Tue Sep 22, 2009 8:10 am
I though it also depended on the type of tire you had in the first place. Like the tread direction and design also affected this.
aleki2424
Postby Taido » Tue Sep 22, 2009 12:51 pm
Unless you want to remove the tires from the rims, flip them around, and put them back on every time you rotate them, don't crisscross with directional tires.
Taido
Audiophiliac
Audiophiliac
