SolaraGuy.com • View topic - How do you tell if a 2007 Solara Sport V6 has VSC
Postby xcgames » Sat Sep 05, 2009 10:32 pm
Noob question but I can't find the answer to that on the internet. So what do i look for in the car to see if it has the vehicle stability control or possibly traction control installed?
xcgames
Postby ThatVietGuy » Sat Sep 05, 2009 10:39 pm
Punch it in dirt or wet surfaces.
ThatVietGuy
Postby xcgames » Sat Sep 05, 2009 10:44 pm
lol
There are no buttons/indicator lights in the dash?
xcgames
Postby kingkakyle » Sun Sep 06, 2009 1:30 am
if i remember correctly all v6 gen 2+ solaras have vsc
Postby xcgames » Sun Sep 06, 2009 11:05 am
kingkakyle wrote:if i remember correctly all v6 gen 2+ solaras have vsc
toyota website displays VSC/TC as an option for 08, i suppose it's the same as for 07 as well.
xcgames
Postby Sparky5e » Sun Sep 06, 2009 12:02 pm
It was an option on my 07SLE as well. There is an annoying beeper and light on the dash when the VSC kicks in. Believe me it kicks in when you play in the snow or get aggressive on wet roads. That is unless you drive like a granny.
If you have it, there is a dissable button left of the wheel on the lower dash. When pressed an indicator icon will light up on the dash.
Sparky5e
Postby xcgames » Sun Sep 06, 2009 5:35 pm
i see. On my Sport there's just a black plastic cover, i take it the car doesn't have VSC. thanks
xcgames
Postby Sparky5e » Tue Sep 08, 2009 7:31 am
I noticed there's a difference between Traction Control and Vehicle Stability Control.
The button I mentioned disables the TC but not the VSC. The TC cuts the power to the wheel while VSC works the brakes. I am not sure if the 2 can be gotten separately or if package together. Mine has both.
07 SLE Convertable
Blue Streak Metallic
Sparky5e
Postby Black Bob » Tue Sep 08, 2009 8:11 am
There should be a "Trac Off" button above your "Tire Pressure Warning Reset" button to the left of your steering wheel right by your left knee. If you don't see it you don't have traction control nor do you have vehicle stability control being that they both are equipped together. As far as I know it was always an option, even on the SLE models.
On my coupe I have one security button and two 'dummy' buttons for the convertible options. I think I've seen some Gen 2 coupes with no dummy buttons.....odd.
Black Bob
Postby NightRider » Wed Sep 09, 2009 4:23 pm
Sparky5e wrote:It was an option on my 07SLE as well. There is an annoying beeper and light on the dash when the VSC kicks in. Believe me it kicks in when you play in the snow or get aggressive on wet roads. That is unless you drive like a granny.
My VSC kicks in when I take corners fast sometimes or when after I take corners hard and I accelerate fast then it kicks in :wink:
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Start The Car
Postby red2002solara » Thu Sep 10, 2009 12:17 pm
When you start the car the VSC button will briefly flash; that will tell you if you have VSC. My SLE V6 has VSC and Trac, but I can only turn Trac off. VSC stays on all the time.
red2002solara
Postby youngblood » Mon Sep 14, 2009 6:13 pm
Damn! I can't imagine pushing the car that hard!
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby SoSleek » Tue Sep 15, 2009 9:54 am
I believe all V6 Gen 2 Solaras have VSC, and all should have push button traction control unless it's a sport. Sports will have traction control unless in Tiptronic Shifting mode.
SoSleek
Postby Black Bob » Tue Sep 15, 2009 10:57 am
^^^Wrong!
Black Bob
Postby SoSleek » Wed Oct 07, 2009 7:05 am
Black Bob wrote:^^^Wrong!
ok....?
SoSleek
