SolaraGuy.com • View topic - Help Serpentine belt replacement ASAP
Postby Ruski » Sun Sep 13, 2009 10:37 am
I need to replace my serpentine belt on my i4, it has many cracks and strains throughout the belt, im looking for some help. if anyone has a manuel or diagram of how to replace it . Thanks a lot
Postby Taido » Sun Sep 13, 2009 11:00 am
There's a list of manuals in this section. I can't see the pdf's at work but try this one. http://cns-design.ru/files/solara/pdf/2AZ-FE%20Engine%20Mechanical.pdf
Taido
Audiophiliac
Audiophiliac
Postby mazen222 » Sun Sep 13, 2009 1:10 pm
i uploaded the whole camry/solara maintenance manuel a while back
do a search for "rapidshare" on solaraguy
1999, 5 Speed V6
mazen222
Postby Ruski » Sun Sep 13, 2009 5:06 pm
i got it i found one on Tn and also Taidos helped out a lot .Thanks guys
Postby NightRider » Sun Sep 13, 2009 5:11 pm
What made you check on your belt?
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby Ruski » Sun Sep 13, 2009 5:54 pm
well when i bought the car with 45k it wouldn't pass MD inspection so i paid the guy off, im now at 70k and the belt began to crack badly and started frying and squealed like a dyeing pig on start ups , and i travel to wvu a lot and didn't need the belt to snap. it was a pain in the ass to replace took about 30 mins and need another set of hands to compress the tensioner, but all is good
Postby JMSinMaryland » Sun Sep 13, 2009 5:58 pm
Sell that bitch and get yourself a faster car :wink:
JMSinMaryland
Postby Ruski » Sun Sep 13, 2009 5:59 pm
heres some pics of the belt
I have done a lot of maintenance on the car so the belt was the last main thing to do
Postby NightRider » Tue Sep 15, 2009 8:55 am
To me the belt doesn't look too bad. On a scale from 1-10 how hard was it to change? And did you use a OEM replacement?
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby Ruski » Tue Sep 15, 2009 9:54 am
no i did not use a toyota belt i used an oem replacement Dayco is the name. its about an 8 of 10 . you do need two sets of hands. one to compress the other to align the belt. the good thing is u dont have to remove anything at all. you compress the tensionor and slide the belt off. the hard part is getting it to go back on and in the right travel pattern. the key is to align all the grooved pulleys first then compress again and slide the belt onto the smooth pulleys and then ur done, let the car run for 5 min and recheck that the belt is seated.
My belt needed to be replaced at 40k and i had the car looked at again at 70 and the shop told me to replace it plus it was squealing really bad on ideal and while driving. whats $30 better then paying for a timing belt change. which im so glad we dont have to do on our cars
Postby anwagbo3000 » Tue Sep 15, 2009 10:27 am
^ wait, gen 2 solaras do not have to have their timing belt chnaged
anwagbo3000
Postby Ruski » Tue Sep 15, 2009 10:30 am
no we have a chain and one belt that controls all of our accessories
Postby anwagbo3000 » Tue Sep 15, 2009 10:31 am
word......wait, so then what do we need changed at 90k....do we have to have the chain changed....
anwagbo3000
Postby anwagbo3000 » Tue Sep 15, 2009 10:37 am
oh wait, i have a v6, nevermind
anwagbo3000
Postby Ruski » Tue Sep 15, 2009 10:46 am
yes 04 to 06 have timing belt, 07-08 have chains V6 models
