SolaraGuy.com • View topic - High Mileage Solara Problems
Postby HomeboyMI » Tue Sep 22, 2009 7:55 am
I was reading the post that people were going over 100,000 miles with their Solara. Please inform us of what parts you have had to replace and approximately what miles were on your car when you did.
I have 35,000 on my 04 and the only thing that went bad so far was the battery with a shorted cell about a month ago. Original tires and brakes are in great shape. Average 34mpg with paper and pencil. Change my own oil and rotate tires every 5,000 miles. Changed air filter at 25,000 to the KM filter.
I hope you high milers will let us know how your starters, alternaters etc have held up.
Thanks
HomeboyMI
Postby NightRider » Tue Sep 22, 2009 8:58 am
Right now I have about 76k and the problem I've had so far was a faulty radiator hose and I changed it myself. That's it so far and I hope it stays that way for a long while...
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby Ruski » Tue Sep 22, 2009 9:37 am
71k here only major change was my serpentine belt
Postby CASTRO » Tue Sep 22, 2009 9:41 am
Got 230k on mine. it was supercharged @ 70k. Only problems were:
-needed new batteries (on my 3rd one)
-Alternator felt like it was weak @ 200k so replaced it with a highlander unit
-re greased both rear hubs due to noise
-trunk cable (release) snapped so now gotta use a key each time
-driver side speaker went out so i upgraded with components :D
other than that, it still sees boost every day and runs like a champion
CASTRO
Postby GzNutz » Tue Sep 22, 2009 1:58 pm
Ruski wrote:71k here only major change was my serpentine belt
Same here...serp. belt. Along with brake pads and a tranny flush.
Postby Ruski » Tue Sep 22, 2009 2:47 pm
yea same just did tranny drain and fill, next is radiator fluid
Postby kingkakyle » Wed Sep 23, 2009 3:35 am
went to dealer today
getting a new cat and water pump
somehow my waterpump cracked *shrugs*
im just shy of 50k on my 05
Postby Midias » Wed Sep 23, 2009 4:17 am
173K
Struts, brakes (a few times), Tires, battery, 1 knock sensor, ebrake shoes, blower resistor, belts (timing and serpentine), water pump with timing belt and the valve on top of the charcoal canister.
That's it I still have the original alternator, radiator, clutch ect....
Postby Ilovemylara » Wed Sep 23, 2009 4:52 am
133,000 miles. I've replaced serpintine belt, brakes, rotors, and the fuel filter (which to my surprise wasnt stuck on, like most other gen 1s seem to have happen.)
Postby Black Bob » Wed Sep 23, 2009 10:13 am
At 80k I replaced 4 air fresheners and a set of tires, no other problems.
Black Bob
Postby Ruski » Wed Sep 23, 2009 10:17 am
kingkakyle wrote:went to dealer today
hmm interesting my mom rav4 with 50 k had a cracked water pump, ive read that it happens alot on the newer i4 models , especially in Rav4
