SolaraGuy.com • View topic - Brakes, and I Paid
Brakes, and I Paid
Brakes, and I Paid
Postby krenshaw » Mon Oct 26, 2009 5:45 pm
Started going to a dealership in College Station, TX, becuase my folks live there, and I would just drop my car off first thing and then go visit my folks, but anyway, enough of the preambles:
I paid just under 500, for new pads front and rear, they turned all 4 rotors, and also had them bleed the system and replace.
I stressed the bleed becuase I've had them just replace a set of pads before and they just leave the old black stuff in there. anyway real happy with the job they did.
krenshaw
Postby TLMNICK » Mon Oct 26, 2009 5:49 pm
I guess that's not too bad if you can't do the work yourself. I personally prefer to take my time, and do everything the way I like it. Plus is a lot cheaper that way.
When you say you had them "bleed" your system, do you mean that you had them flush it out?
TLMNICK
Postby NightRider » Mon Oct 26, 2009 5:53 pm
Did they give you a price on how much w/ all new rotors? Instead of turning them?
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby krawzyazn » Mon Oct 26, 2009 6:20 pm
thats a grip u got ripped
Postby onefiend » Mon Oct 26, 2009 6:47 pm
Could have bought new rotors too for that price, instead of just turning/resurface. You over-paid.
onefiend
Postby krenshaw » Mon Oct 26, 2009 6:55 pm
Yea they flushed the system, too bad I don't bother to do it myself, no I didn't get a quote on new rotors.
krenshaw
How much did I overpay?
Postby krenshaw » Mon Oct 26, 2009 6:58 pm
How much do all estimate I overpaid? Aside from doing it myself.
Thanks
krenshaw
Postby GzNutz » Mon Oct 26, 2009 7:14 pm
I had a local shop do mine, and I am glad I did. I had a few seized bolts and a bent bracket. I sourced the parts and paid $130 for labor. Midwest salted roads suck!
Postby DriDed » Mon Oct 26, 2009 7:42 pm
Pay $1500 more and you could have gotten a stoptech big brake kit.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby Chinky420 » Mon Oct 26, 2009 8:31 pm
don't know how much it costs to bleed a system, but if you were a DIYer, and did it yourself
brake pads, front+back = approx 60-120 depending on quality of pad (let's assume 60, since it's a brake shop, and they're not known for using premium pads unless you specify)
turning 4 rotors = approx 20 bucks for all 4
new brake fluid = approx 20 bucks (depending on quality and quantity...never bled a system myself, so i don't know the usual volume used)
which comes out to about 100 bucks in parts
and i would estimate a 4 wheel brake job + bleed to take about 2.5 or 3.0 hours of labor,
so labor at 40/hr x 3 = 120
comes out to around $220
this is a very very very rough estimate....like i said, i don't know how long it takes to bleed a system (i assumed 0.5 - 1.0 hour), nor do i know how much their hourly rate on labor is, but it takes me about an hour to do one set of brakes (front), so i multiplied that by two (front+back = 2 hours, IMO)
for $500 you coulda gotten a twin caliper set (from here), a rebuild kit, bigger pads, and new rotors, and brake fluid, and probably come out a little cheaper (if you DIY). i'm not saying this to rain on your parade, i'm just using this as an example to compare the amount spent.
btw, check out the texas meet plans....they're in the in the events section, the meet is on nov 7th in austin
Chinky420
Postby krawzyazn » Mon Oct 26, 2009 8:47 pm
OEM pads $80-100 for front and rear
if you go to the right place they will install, turn your rotors, and include fluid for $60 per axle
Bleeding the brakes is a must when installing new pads so there is no need to request it
for $500 I would have gotten gabes relocation kit
Postby LEE337 » Mon Oct 26, 2009 9:02 pm
^I bought Gabes kit and spent about $500. Maybe a little more. :D
That included:
Brackets
13" slotted/drilled rotors
slotted/drilled rear rotors
Goodrich SS brakelines
EBC Redstuff pads
DOT 4 brake fluid
Red caliper paint
Ok, ok closer to $650... :D 8)
Did the entire install myself, including bleeding the system.
I must say well worth the dough. She stops on a dime now. 8)
Postby krawzyazn » Mon Oct 26, 2009 9:24 pm
ooh wait its a gen 2 lol will the bracket fit?
Postby jetbtkng » Mon Oct 26, 2009 9:31 pm
little tire shop down the street, complete brake job all 4, $150....... :drinking:
Postby NightRider » Wed Oct 28, 2009 9:12 am
^^^ Super juug on that price. Damn thanks for all the info cause I need to get my car done. I havent serviced my breaks since I bought the car and she still stops good as of today but I know I need to get mine done soon the pad wear is a bit on the low side.
Injen polished SRI
TRD FSB 6000K HID's
NightRider
