SolaraGuy.com • View topic - Gas gauge issue
Gas gauge issue
Gas gauge issue
Postby Taido » Mon Nov 02, 2009 1:56 pm
My gauge's calibration must be wrong or something. Cause I filled up the other night but the gauge shows I'm at 3/4 of a tank. Any suggestions?
Taido
Audiophiliac
Audiophiliac
Postby 1gSE » Mon Nov 02, 2009 2:36 pm
the float maybe?
Solara-M62 @ 5.5psi
1gSE
Postby kenny6683 » Mon Nov 02, 2009 2:48 pm
this used to happen to me when i had the reverse indiglo gauges installed...if you do then that could be a possibility to your problem but if not then i dont know :)
kenny6683
Postby dug320 » Mon Nov 02, 2009 3:29 pm
My experience tells me it is very full. Once you drive around and it starts to empty it will register full.
This seems to be normal in the Camry world.
dug320
Postby Taido » Mon Nov 02, 2009 3:39 pm
How would I be able to check if it's the float? Cause I've driven around a bit and it just goes down.
Taido
Audiophiliac
Audiophiliac
Postby DriDed » Mon Nov 02, 2009 4:36 pm
One time I went to the gas station to fill up my car with 3/4 of gas remaining and the needle didn't go up afterwards when I started the car after filling up.
Funny thing is the car won't do that if I fill up the gas when the car only has 1/2 tank of gas or less remaining.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby Taido » Sat Nov 07, 2009 1:47 pm
Okay I'm gonna try to just figure out how much gas I actually have in the tank, cause right now it's registering as empty when I filled it up just a few days ago. Also bumnping for anyone else that might have an idea.
Taido
Audiophiliac
Audiophiliac
Postby wkbrdr91 » Sat Nov 07, 2009 4:43 pm
DriDed wrote:One time I went to the gas station to fill up my car with 3/4 of gas remaining and the needle didn't go up afterwards when I started the car after filling up.
I usually fill up before my gas gets even 3/4 left... and its never happened to me. must be an 04 problem
2006 Solara Sport
wkbrdr91
Postby JamesT » Sat Nov 07, 2009 9:04 pm
I've always used my trip odometer to measure distance per tank. It's been something I've done since I've had my car.
Every time I fill up, I reset the trip odometer just in case the float in the gas tank stops responding.
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby Taido » Fri Nov 13, 2009 8:04 am
The gauge works now. ECU reset fixed it. Thanks for the help guys. ^-^
Taido
Audiophiliac
Audiophiliac
Postby NightRider » Fri Nov 13, 2009 11:42 am
That's all you had to do? Damn ECU's
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby Taido » Fri Nov 13, 2009 12:40 pm
I know right. But I think the pulley install made it go crazy. Only reason I can think of. xD
Taido
Audiophiliac
Audiophiliac
