SolaraGuy.com • View topic - FRONT WOBBLES- HELP!
Postby Joe Cat » Fri Dec 11, 2009 6:22 am
So the prior owner hit a pot hole and benyt the original wheel - then he brought the car tyo the dealer and put a new rim and tire and had an alignment done-
The car still wobbles and the steering wheel is still cocked a bit- Anyone have any idea what it could be??
Joe
Joe Cat
Postby DriDed » Fri Dec 11, 2009 7:31 am
Have a dealer look at it, my dad ran up a median and did more than an alignment. He paid $500 for the job.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby LEE337 » Fri Dec 11, 2009 8:33 am
Replace your wheel bearing.
Also, check the tie rod, CV half shaft, and your end links.
Postby System_Crash » Sat Dec 12, 2009 12:45 pm
A good service shop should have caught a bad wheel bearing (saftey issue) I would return to the same dealer and tell them that the steering wheel is not centered and have them check if any suspension/ steering/ or bearing parts are bent/damaged. Is the wobble only when hitting the brakes? or driving down the road?
Pearl White 2004 Solara V6 90,000 miles
System_Crash
Postby Joe Cat » Sat Dec 12, 2009 12:56 pm
running down the road! tyhe slower the more i feel it- It has gone to an expert alignment show _ I Will keep you posted!
JOE
Joe Cat
Re: FRONT WOBBLES- HELP!
Postby gnegroni » Thu Jan 26, 2012 7:30 pm
Way to wake up a dead post...
I believe I'm having the same issue. What solved your problem?
gnegroni
Postby gnegroni » Fri Feb 03, 2012 9:33 pm
Well, I found my problem:
Replaced the front wheel bearings and no more groaning, cyclic wobble or steering wheel vibration. My car had 120k miles when I replaced them, but it feels like they were way past due since one of them was looking like rainbow colored (LOL). Paid around $45 for each replacement front bearing (they make the Toyota OEM ones).
I still have some vibration caused by pothole damaged tire, but no more noise... it was really bad, even more noticeable when doing corners. I could have easily confused the noise with tire noise when replaced the tires, which makes me wonder what would be the typical replacement interval.
From what I can think of, the main culprit could have been potholes, damaging tires and wheels, which would effectively end up causing excess stress on the bearings itself.
Glad I had that fixed
gnegroni
