SolaraGuy.com • View topic - Replacing fog lamps? help!!
Postby SoLarry » Sat Jan 16, 2010 7:01 pm
Hi all
I was just wondering how much of a pain is it to replace the bulbs in the fog lights. According to the owners manual you should see the dealer. I searched the forums and the net for over an hour for the answer....help! :o
1991 Oldsmobile Toronado
2004 Toyota Solara SE
SoLarry
Postby kingkakyle » Sun Jan 17, 2010 5:05 am
depends on how skinny you are
i just put my hand in the lower opening and reached no problem
Postby [SMAN] » Sun Jan 17, 2010 7:11 am
Just unbolt the splash guard under the car and you should be able to access them.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby sahuddleston » Sun Jan 17, 2010 8:51 am
on the gen1's it was relatively simple as well. are you replacing the oem bulbs with another oem bulb or upgrading them?
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby SoLarry » Sun Jan 17, 2010 8:56 am
The bulbs in there now are the blue tinted ones, I think they might be a cheap set because when I got the car the fuse had burned out. I'm going to get a set of OEM type bulbs before I replace the fuse, I'd hate to replace the fuse and have it burn out again as soon as I turn the lights on.
SoLarry
Postby SoLarry » Sun Jan 17, 2010 4:21 pm
I took kingkakyles advice and reached them through the lower grille opening. The drivers side was easy, getting to the passenger side was a bit more tricky. When I removed them I realized that they were a pair of 9005's and not the 9145's that are listed, which makes me wonder if that is why the fuse was blown. Popped the new bulbs in, put the new fuse in (finding the low-profile mini fuses was a PITA, had to go to 3 stores before finding them!) and now I'm good to go.
SoLarry
Postby GzNutz » Sun Jan 17, 2010 8:11 pm
Good to hear it was just the bulbs that popped the fuse.
