SolaraGuy.com • View topic - Pulling my shorts up now
Postby krenshaw » Fri Apr 16, 2010 11:28 am
got raped at Toyota today, bill is going to be if im lucky, just uneder 1300 hundred, dropped off my car for the all you can do timing belt service, listed below, then I got the call approx. an hour later, we need to change you plugs, 329 dollars,
I said they are just plugs, he said we got to take the plenum off anyway I said do it because I remember someone was talking about plugs here in the forum and the engine was designed by aliens or something.
Then he wanted to change my pwr steering fluid, I said its' a flush right, he said yes, I asked the system holds more than is just in that reseivour, he said yes, I said do it, Man I feel Depressed.
krenshaw
Postby no_escape » Fri Apr 16, 2010 11:36 am
don't feel too bad. I'm having my supercharger rebuilt, and I have to replace my knock sensors, valve cover gaskets, belt, brakes, put on my superpro bushings, oil change, plugs, coolant, and dyno tune this summer. Hopefully all done before I get a lung transplant.
no_escape
Postby 1gSE » Fri Apr 16, 2010 11:45 am
HOLY :bleep: 329 for plugs??? Don't pay for that. I'm sure it cant be any worse than plugs on 1g, but damn....i got my timing belt done for about a hundred bux more, and i change the plugs in a few minutes
Solara-M62 @ 5.5psi
1gSE
