SolaraGuy.com • View topic - tire sensor light - HELP!!! wont shut off
Postby Joe Cat » Wed May 12, 2010 11:07 am
I have an 2008 SLE convertible
I check and mad all the pressure 31-32 pounds- NOT THE SMALL SPARE IN THE TRUNK AS THE MANUAL STATES IT DOES NOT HAVE A SENSOR AND THAT PRESSURE IS LIKE 55 pounds.
I press the black button on the dash= With key on engine off and engine on and in neutral and still cant get the stinking light off. Any help would be great! joe
Joe Cat
Postby kingkakyle » Wed May 12, 2010 11:14 am
u have to hold it until the light slowly blinks 3 times
Postby Joe Cat » Wed May 12, 2010 11:22 am
I do and have held it down and it still does not blink slower?? how long would you say you should hold it down cause i did it for about 40 seconds.joe
Joe Cat
Postby rollaevo99 » Wed May 12, 2010 2:18 pm
my 04 doing the same crap.....help anybody?
Postby SoLarry » Wed May 12, 2010 3:18 pm
Joe Cat wrote:I do and have held it down and it still does not blink slower?? how long would you say you should hold it down cause i did it for about 40 seconds.joe
Are you pushing the button down while you are stopped? I've noticed that it won't reset while the car is moving....you have to be at a complete stop. Mine usually resets after I've pushed the button for about 10-15 seconds.
1991 Oldsmobile Toronado
2004 Toyota Solara SE
SoLarry
Postby kingkakyle » Wed May 12, 2010 5:16 pm
car needs to be stopped
i think the ignition needs to be on as well
but yea 10-15 seconds i think and it will blink 3 times about 1-2 seconds apart
Postby Joe Cat » Wed May 12, 2010 5:37 pm
yes car is stopped, engine is off-
and in "n"
dO YOU THINK i SHOULD DISCONNECT THE BATTERY FOR A BIT??
joe
Joe Cat
Postby SoLarry » Wed May 12, 2010 5:44 pm
I think the car has to be running and in park...try that, if that doesn't work then I might try disconnecting the battery
SoLarry
Postby Joe Cat » Wed May 12, 2010 9:23 pm
loved my tornado! light blue with factory sunroof!
Joe Cat
Postby kingkakyle » Wed May 12, 2010 9:31 pm
yea ur car has to be on
and not in neutral
Postby GzNutz » Thu May 13, 2010 5:17 am
With the car off I hold the button in for a few seconds, turn the ignition to acc (still holding button) for a few seconds, then start the car (still holding button in) for a few more seconds. Then let go and the light remains off.
Re: tire sensor light - HELP!!! wont shut off
Postby yaddadaimsayin » Tue May 18, 2010 9:06 pm
i hold it and it'll blink for a bit then shutoff... for like a minute.
