SolaraGuy.com • View topic - Unable to Reset Maintenance Light
Postby Gunga » Tue Jul 13, 2010 8:33 am
2006 SLE 30K
Maintenance Light came on at 30K. Have tried the process below 4 times. Did not work. I have reset the light before.
Any ideas. BTW; Last Try, Held the trip meter button down for a minute.
Step 1 Turn the key to the 'on' position.
Step 2 Reset both trip meters to zero. you can reset the trip meters to zero by selecting trip A or trip B and holding in the trip meter button for five (5) seconds.
Step 3 After both trip meters are reset, select any trip meter and hold in the trip meter button and start the car.
Step 4 Continue holding the trip meter button until the "maintenance required' light disappears.
Gunga
Re: Unable to Reset Maintenance Light
Postby NightRider » Tue Jul 13, 2010 9:05 am
Try resetting the ECU by disconnecting the battery (negative) terminal or removing the fuse.
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby [SMAN] » Wed Jul 14, 2010 6:47 pm
Try this. Open your door. Press and hold the odometer rod in. Then turn the key from off to on and watch the display reset.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
