SolaraGuy.com • View topic - Removing the jack from the trunk?
Postby panic » Sat Aug 28, 2010 12:33 pm
Had the car for 2 years, never used the jack (inspected it when bought froma Toyota dealer, looks clean and normal).
Read the owner's manual - the method described ("turn this to release") doesn't work because the jack has no such part. There's no release, lever, sticker, handle, screw - nothing.
Maybe it's not the correct jack?
panic
Re: Removing the jack from the trunk?
Postby kingkakyle » Sun Aug 29, 2010 2:08 pm
if i remember correctly, you use that tire iron to turn a part to release the jack
because it is slightly expanded to hold it in place, you have to "lower" the jack to loosen it
