SolaraGuy.com • View topic - Fornt hub bearing size 29 or 30mm socket?
Postby GNasty » Mon Jun 13, 2011 11:54 pm
Do I need a 29mm or 30 mm 12 point socket top remove hub nut?
Anyone know what size socket I need will be greatly appreciated
I'm also going to do the cv joints while I do bearings.
New gen solara bearings have to be pressed in with a special bearing press.
--so it looks like i gotta get a rent a car while I work on it.
GNasty
Re: Fornt hub bearing size 29 or 30mm socket?
Postby Gregtrd » Tue Jun 14, 2011 12:39 am
Neither one, its 32mm
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
