SolaraGuy.com • View topic - New owner, TRD exhaust question
Postby lifelesslived17 » Sat Feb 04, 2012 7:23 pm
I noticed some paperwork in my glove compartment regarding my car's TRD exhaust system. Did the SE trim level come with that stock, or did someone upgrade to that? Regardless, I like the way it sounds!
lifelesslived17
Re: New owner, TRD exhaust question
Postby crispone » Sat Feb 04, 2012 7:27 pm
lifelesslived17 wrote:I noticed some paperwork in my glove compartment regarding my car's TRD exhaust system. Did the SE trim level come with that stock, or did someone upgrade to that? Regardless, I like the way it sounds!
That is not a stock item. Someone had the TRD exhaust installed, and to your point, they DO sound great and work well on the car. It's a good, quality upgrade, and you are fortunate to have it as part of your purchase. :wink:
...now... compliment that exhaust with a CRISPMONGO AIR FILTER MOD and you'll be set! (Recommended with the CP-e INTAKE if you can get one!)
Postby lifelesslived17 » Sat Feb 04, 2012 9:02 pm
it also has a big sticker on the airbox to let me know there is a trd air filter installed, so ill stick with that. Thanks for the info though!
lifelesslived17
Postby lifelesslived17 » Sun Feb 05, 2012 8:57 am
btw crisp, where in ohio are you located? CLE here
lifelesslived17
Postby crispone » Sun Feb 05, 2012 5:28 pm
lifelesslived17 wrote:btw crisp, where in ohio are you located? CLE here
West central region. I'm generally incognito, as I move around the Midwest, Canada and Japan a bit for work. :wink:
