SolaraGuy.com • View topic - Engine Sludge with only 35k miles
Postby alky181 » Fri Apr 06, 2012 2:12 am
I purchased the 2007 SLE 2.4L, with only 26k. I have been using Mobile 1 Extended Performance with the Ext Per Filter. The only upgrades I did were the Pulstar Spark Plugs and a Volo Chip. Any suggestions as two why I have Engine Sludge.
Jeff
alky181
Re: Engine Sludge with only 35k miles
Postby Noah » Wed Apr 11, 2012 11:56 am
Weird, I have only used OEM Oil, filters and original spark plugs and have zero problems at 110k miles. I'm thinking the higher performance oil and spark plugs are too much for our engines?
Noah
Postby mig0s » Thu Apr 12, 2012 11:05 am
^^it has nothing to do with 'higher performance oil'. To OP, most likely because you bought a 5 years old car with 26k. For most of the time, the car might have been parked. Can you post a picture so we can see how bad it is?
mig0s
Postby Black Bob » Mon Apr 16, 2012 8:18 am
I'm guessing what mig's is guessing. I'm also suspect of the previous owner not changing the oil regularly and the engine just needs a complete flushing to get the stuck-on gunk out of there. Barring that, make sure your engine is reaching temperature--the biggest cause of sludge (second only to over-extended oil changes) is a cold running engine.
Black Bob
Postby gnegroni » Wed Apr 18, 2012 9:56 pm
Pictures please
gnegroni
