SolaraGuy.com • View topic - rattle noise at highway speed
Postby murf » Wed May 23, 2012 5:40 pm
Hi all, new to the forum. Sold the Lexus RX and now have a 2008 Solara SE in the Metallic graphite gray. I have ordered the new wheels and tires - will post up when theyre installed :D
My question: Has anyone run across a rattle type noise at highway speed coming from the sideview mirror area. definetly related to wind speed. its outside the vehicle and transfers into the cabin.
Any ideas would be appreciated.
murf
murf
Re: rattle noise at highway speed
Postby SteveSolara » Fri May 25, 2012 12:26 am
hmm, can we get a video clip or audio clip?
Image Image
SteveSolara
Postby Black Bob » Fri May 25, 2012 8:42 am
The sideview mirror housings are held to the door by only one nut, my first guess-stimate would be at high way speeds the nut is just loose enough to allow wind at highway speeds inside where the mirror connects to the door. First physically check any possible play in the mirror housing--there should be absolutely zero movement. Also, make sure the mirror itself hasn't become loosened inside the mirror housing, you should hear clicks as you manually move the mirror with your finger.
The mirror housing can be accessed by popping off the triangle piece inside the door, however I have no clue how to tighten the mirror itself.
Black Bob
Postby murf » Sun Jun 10, 2012 6:49 am
Turns out what was happening was the bolt holding down the front part of both inner fender liners were missing and when on the freeway the wind would blow back the thin plastic onto the tires. the had holes in them from wearing. like most noises it was hard to tell the origin and the noise transmitted unusually through the car from all the way up there. all fixed now. thanks for the replys
murf
Postby SteveSolara » Sun Jun 10, 2012 8:19 am
LOL glad you found it, make sure your tires are ok too
Image Image
SteveSolara
