SolaraGuy.com • View topic - Tach isn't reading correctly and my catalytic conv is bad
Postby philosophicaljt » Sat Jun 23, 2012 7:02 am
I've got an 04 Solara XLE V6 with about 145000 miles on it.
For the past 6~8 months, my tachometer is reading below zero at idle, and reading low while driving. I went to the dealer, they said the cluster was bad, but that it wouldn't effect the motor in anyway.
I was driving down I-70 yesterday at 70mph (w/cruise) with the windows down and the A/C off for about an hour. I look down and the check engine, TCS and VSC lights are on. Sigh. I go to the dealer. They say its a PO420 core, and that the catalytic convertor is clogged/clogging. They cleared the code and I went home.
Is it worth trying to "clean" the catalytic convertor out? Unbolting it, and trying to get whatever loose broken-down material is in there, out. I really don't want to replace it right now, we are in the process of buying a fully loaded Camry Hybrid, and I would rather spend my time than my money (fixing, not replacing)
Thoughts? Is there a chance the tach and catalytic convertor issues are related?
2004 Solara SLE V6
Search
philosophicaljt
Re: Tach isn't reading correctly and my catalytic conv is ba
Postby SteveSolara » Sat Jun 23, 2012 10:09 am
You can try taking it off and flush it like this
And for the other stuff, i think it was tied along with the catalytic converter
Image Image
SteveSolara
Postby philosophicaljt » Sat Jun 23, 2012 12:36 pm
I appreciate the video!
But the tach is still off. At idle it still reads below zero.
2004 Solara SLE V6
Search
philosophicaljt
Postby SteveSolara » Sat Jun 23, 2012 4:11 pm
Have you tried unplugging the negative terminal from the batter for 30sec and plug it back in?
Image Image
SteveSolara
Postby philosophicaljt » Sat Jun 23, 2012 5:58 pm
SteveSolara wrote:Have you tried unplugging the negative terminal from the batter for 30sec and plug it back in?
yup. Let it set for 30 minutes without a battery connected to totally clear anything. Tach is still wrong :(
2004 Solara SLE V6
Search
philosophicaljt
Postby SteveSolara » Sat Jun 23, 2012 6:44 pm
hmm i guess the only other way to check for sure is to actually take it out and check behind it and see whats up
Image Image
SteveSolara
Postby GzNutz » Sat Jun 23, 2012 7:50 pm
It may not be getting the correct voltage. I don't have it front of me but my voltmeter has a setting for rpms. I've used it to check readings at the car's ecu. There is a different wire that feeds the tach directly though. I'll take a look at the PDFs tomorrow evening to see if I can locate the specific wire that may be at fault.
Postby philosophicaljt » Sun Jun 24, 2012 4:26 am
GzNutz wrote:It may not be getting the correct voltage. I don't have it front of me but my voltmeter has a setting for rpms. I've used it to check readings at the car's ecu. There is a different wire that feeds the tach directly though. I'll take a look at the PDFs tomorrow evening to see if I can locate the specific wire that may be at fault.
I've got the EWD from toyota, I could find it if I thought that would help. If I found the wire, and it wasn't giving enough voltage, then what? That would mean the Cam position sensor is bad? Or whatever feeds the tach. That seems even worse, lol.
2004 Solara SLE V6
Search
philosophicaljt
Postby philosophicaljt » Sun Jun 24, 2012 4:30 am
SteveSolara wrote:You can try taking it off and flush it like this
Yuck, the PO420 code is for bank 1 I believe. And the Catalytic convertor is built into the header, so I can't even see through it.
So, I need a new header/converter. This is slowly becoming an extremely expensive fix. I am hoping the O2 sensor is going, but I've never known one to "die slowly". They have always "just failed" in my experience.
2004 Solara SLE V6
Search
philosophicaljt
Postby GzNutz » Sun Jun 24, 2012 4:39 am
It may just be a short in the line. Hopefully it's just a loose wire otherwise running a new wire may be a cheaper option to tackle before replacing a cam sensor.
Postby philosophicaljt » Sun Jun 24, 2012 9:02 am
well, Its the bank 1 sensor, so it's the side nearest the firewall. Yuck. Giant pain in the ass. I could barely get the multimeter leads down to test the O2 sensor. Sadly, it was within range. So I am guessing my catalytic converter is on its way out. I am going to go flog it for a bit on the highway since it's pretty warm today (90F) and see if it comes back. If it does, I will probably end up letting a shop replace it.
Yuck.
As for the tach, I have been reading the EWD, and can't seem to find which wire actually sends the signal. I assume its a 5v signal, but I'm not sure.
2004 Solara SLE V6
Search
philosophicaljt
Postby philosophicaljt » Sun Jun 24, 2012 9:06 am
I uploaded it to 4shared, not sure if you need an account to access it or not: (looks like you do)
http://www.4shared.com/office/2BumrrR9/EWD.html
2004 Solara SLE V6
Search
philosophicaljt
Postby GzNutz » Sun Jun 24, 2012 6:25 pm
If you access the ecu behind the glove box the wire for the tach is black with an orange stripe and is in plug F pin 5. According to the diagrams it should be the same going to the tach itself. I've got the position of plug F from my urd maf-sc manual, it may be referred to as plug A in the toyota manual. I will be tearing into my ecu on Wednesday and can take pics of the wire if you'd like.
I'm guessing that if your cam sensor was the issue you'd have many more problems than just a bouncy tach, ie ignition/revving. It most likely is a bad cluster and you're best bet would be a pick and pull. LKQonline.com has them listed for around $120.
I hope this helps.
Postby philosophicaljt » Mon Jun 25, 2012 4:40 am
GzNutz wrote:I'm guessing that if your cam sensor was the issue you'd have many more problems than just a bouncy tach, ie ignition/revving. It most likely is a bad cluster and you're best bet would be a pick and pull. LKQonline.com has them listed for around $120.
I hope this helps.
Very helpful indeed! Thanks a lot :)
And sadly, you are correct, it is the cluster. Stupid opitron gauges are expensive. But thanks for the link!
2004 Solara SLE V6
Search
philosophicaljt
Postby SteveSolara » Tue Jun 26, 2012 8:17 am
Hey i found this video, hopefully it helps
Image Image
SteveSolara
