SolaraGuy.com • View topic - the button
the button
the button
Postby angelo » Tue Oct 07, 2003 10:43 am
What does the button located under the Trac Off one actually do?
I have SLE V6 with VSC...
angelo
Postby fotodad » Tue Oct 07, 2003 11:16 am
See page 131 in owner's manual. I'm not trying to be a smart *ss. The manual just explains it far better than I could.
2004 Solara SLE
Lunar Mist/Graphite
InvisaGuard
20% tinting all around
Michelin Pilot A/S
fotodad
Postby angelo » Tue Oct 07, 2003 11:20 am
fotodad wrote:See page 131 in owner's manual. I'm not trying to be a smart *ss. The manual just explains it far better than I could.
I found it in the manual, but unfortunately it is in French :cry:
angelo
Postby LunarMistGray » Tue Oct 07, 2003 2:49 pm
It's the tire pressure warning system reset switch. If the tire pressure warning system light comes on while driving, then according to the manual you should adjust the your tire pressure if needed and push the reset switch for 1 sec. If the light remains on then you should take it in to the dealer. There's a lot more info in the manual on pgs 135-139.
LunarMistGray
