SolaraGuy.com • View topic - difference between 04 Solara V6 and the V6 in RX330 & Si
Postby angelo » Sun Oct 19, 2003 3:33 pm
the same engine is rated 225 hp in (Solara, ES330) and 330 hp in (Sienna, RX330) - is it just a chip programming?
angelo
Postby TW85 » Sun Oct 19, 2003 3:56 pm
You may want to correct that to 230 HP. :wink:
TW85
Postby geminimouse » Sun Oct 19, 2003 4:03 pm
Where did u see that the sienna and rx has 330 hp? It's listed as 230 hp. (oops)
http://www.toyota.com/vehicles/2004/sienna/specs.html
http://www.lexus.com/models/rx/specifications.html
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby TW85 » Sun Oct 19, 2003 5:28 pm
The Solara V6 has 225 HP.
TW85
Re: difference between 04 Solara V6 and the V6 in RX330 &
Postby angelo » Mon Oct 20, 2003 3:44 am
angelo wrote:the same engine is rated 225 hp in (Solara, ES330) and 330 hp in (Sienna, RX330) - is it just a chip programming?
Yes, I mean 230 hp :( , there's still a 5 hp difference...
angelo
ours are lighter
Postby bigpow » Mon Oct 20, 2003 12:42 pm
I'd take the 5HP less with less weight too.
Anyone got the weight of Sienna/RX? They must weight more, right?
:o
I'm thinking of CAI mod (+10HP)?
bigpow
Postby TW85 » Mon Oct 20, 2003 1:39 pm
Solara SLE V6 - 3,439 lbs.
Sienna XLE FWD - 4,165 lbs.
RX 330 FWD - 3,860 lbs.
TW85
what would be cool
Postby bigpow » Tue Oct 21, 2003 10:47 pm
You know what would be cool?
Put the 3.3L V6 engine into a Corolla/Celica ~2000lbs -> instant rocket car
bigpow
Postby HKSV6SLE » Wed Oct 22, 2003 12:05 am
for one thing..putting a v6 into a car like the celica would not make sense cuz it would make the car very heavy in front, which is bad enuff cuz its a front wheel drive car and im pretty sure that most of the weight of the car is in the front...could it be done? yeaa....but....seems weird...
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Hammerli » Sat Nov 29, 2003 4:54 pm
Generally most variances in power in models powered by the same engine are due to different intake/exhaust routing. It is generally easier in an SUV to make a straighter exhaust than in a sporty coupe. Also intake routing is often different, which can make a few hp difference. Another possibility is that the SUV/van engine is tuned for more torque at a lower RPM to aid in acceleration, which will affect the rest of the powerband as well.
As far as the V6 in the Celica, no thanks. The 61/39 weight distribution is already bad enough, the last thing I want is more understeer.
2000 Celica GT-S 6 speed
2004 Solara SE Sport V6
Black Pearl Emblems
Blizzak WS-50 215/55/17
Hammerli
Postby Guest » Tue Dec 02, 2003 7:08 am
is not put it on MR2... but too bad all new V6 are auto..
Guest
